Suspension Bushes
Posted: Thu Mar 17, 2011 2:46 pm
by waue1978
When the car had the MOT a couple of weeks ago I got an advisory on anti-roll bar bushes & rear subframe bushes. Contemplating getting these done when it goes in to get the air con fixed, so 2 questions really.
1. How much should it cost for this to be done? She said the anti-roll bar bushes aren't too hard to do, but have a sneaking suspicion the rear subframe won't be too cheap.
2. Are there any uprated items available? A few years ago poly bushes were all the rage, but nobody seems to do them for the 406.
Re: Suspension Bushes
Posted: Thu Mar 17, 2011 4:14 pm
The rear subframe bushes? sounds like the trailing arm bushes to me? if so they can be a bit of a faff - need a press to get them in and have to unbolt a few things etc. for access.
The rear anti-roll bar mounting bushes are up on the rear bulkhead kinda thing but the one on the petrol filler side requires the tank/filler pipe to be dropped slightly to get a socket on the bolts
care is therefore needed to prevent any bits entering the filler neck
Posted: Thu Mar 17, 2011 6:04 pm
by TRAVIS BICKLE
demon tweeks do a range of universal roll bar bushes. Just give them the size you need.
Posted: Thu Mar 17, 2011 6:21 pm
Interesting
Btw the bush clamp bolts have been known to shear so soak the buggers in WD for a few days first.
Posted: Thu Mar 17, 2011 8:06 pm
by omega
poly bushes?
not a big fan would rather buy genuine,look at it this way
1 you know they will fit
2 you know how the car feels
3 if you dont like the way car feels with these bushes on you will have to swap/replace them so more time/money
4 if the originals have been in for so long they have nt done a bad job have they?.
Posted: Thu Mar 17, 2011 8:53 pm
by TRAVIS BICKLE
Ive always replaced worn standard bushes with poly jobbies, but the 406 is not really catered for. ive done a full poly kit an 8K mile scooby sti and the difference was vastly noticeable and it wasnt too harsh either, alittle noisier but felt much more precise.
Posted: Fri Mar 18, 2011 11:20 am
by waue1978
omega wrote:poly bushes?
Very sound logic there.
The rear anti-roll bar mounting bushes are up on the rear bulkhead kinda thing but the one on the petrol filler side requires the tank/filler pipe to be dropped slightly to get a socket on the bolts care is therefore needed to prevent any bits entering the filler neck
Sure she said front anti-roll bar bushes. Didn't think I had a rear anti-roll bar.
Garage doing it for me so hopefully they'll know what they're doing with them.
