rear bushes/links? cost?
Hi, Got a 2001 1.8 d9. Getting some clunking noise from the rear when going over bumps and stuff. Absolutley fine on the smooth stuff. Would it be the rear bushes and rear drop links? If so how much do you reckon on getting these replaced at a normal friendly garage. NOT Kwik Fit!!!! Rather pay for someone else to do it as not that comfortable in doing the job myself! The other option is that I stay on the smooth roads (if any) and avoid bumps!!!!!! Many thanks
- lozz
Re: rear bushes/links? cost?
Hi,
it couid be Top links or droplinks.
whilst the cars weight is on the wheels pull at the top of the wheel if theres play it will be the top links failing.
ive just done mine its fairly easy to do.
the top links are around £18 each for good brands,
on ebay you can pick top links up for under a tenner a pair,
drop links for the rears are pennys
not too costly then. will try the wobble test when i get a chance...thanks
it will probably be the rear top link .
the rear droplinks dont often get mentioned ever . you never hear of any1 on this forum changing them
but the rear toplink is always being mentioned so it will be them
ok thanks. more info the better!!! just so i dont get fobbed off at the garage!!!
your in the right place for more info fella
- lozz
Sod the garages.
Replace it your self its a Doddle, some Tipex and some Spanners is all you need,
is there a guide at all on here on how to do it? only basic tools needed???? plus it would be handy to have a proper jack as wouldnt even contemplate doing it with the one from the car!!!!
- lozz
yes there is a guide on the forum on how to do it.benlowlew wrote:is there a guide at all on here on how to do it? only basic tools needed???? plus it would be handy to have a proper jack as wouldnt even contemplate doing it with the one from the car!!!!
iwill see if ican find a link for it
gave it the wheel wobble test this morning. not much play on the o/s/r but the n/s/r there is quite a bit of movement there!!! top links to be replaced then!!!! thanks
I assume these will be the ones to get?
http://cgi.ebay.co.uk/PAIR-PEUGEOT-406- ... 3a5677d3e8
- 2.2 16v
viewtopic.php?f=10&t=7376benlowlew wrote:is there a guide at all on here on how to do it? only basic tools needed???? plus it would be handy to have a proper jack as wouldnt even contemplate doing it with the one from the car!!!!
Have a look at this.
We've probably all done it, but you should never work under a car thats supported by a jack, no matter how good the jack is. Buy yourself a set of axle stands, they're an absolute essential if you're going to be working on your car.benlowlew wrote:is there a guide at all on here on how to do it? only basic tools needed???? plus it would be handy to have a proper jack as wouldnt even contemplate doing it with the one from the car!!!!
The jack that is supplied with the car is perfectly capable of doing the job it was designed for, so instead of buying another jack - invest in a set of stands, they quite literally could save your life.
I carry a folding axle stand in the car at all times, it doesn't take up much room.
The only other bit of advice I can give you with that particular job is to have a spare bolt available, and stick plenty of penetrating oil on the bolt, and give it time to work before you attempt to undo it. My bolt sheared, the car was off the road, and my nearest stealers is 20 odd miles away
Bolts shearing aside, its a simple enough spanner job.
goes without saying....safety first!!!
- Site Admin & Mad Biker!
I hope you haven't ordered these yet, the ebay ones are a pile of shitebenlowlew wrote:I assume these will be the ones to get?
Get the oe ones from eurocarparts. They aren't much dearer but they are a hell of a lot sturdier!
