Oversteer - Tracking or rear links
For a while now the back end has felt quite lose going round islands and right hand bends, feels a lot more stable on left handers tho.
I'd put it down to rear links and added it to the list of jobs that need doing.
However, I have now noticed significant wear on the outside of the n/s/f tyre, would having 1 front tyre toeing in ( I mean more than usual as there supposed to toe in a little) cause the same symptoms?
Re: Oversteer - Tracking or rear links
When my saloon started getting tail-happy it was the front tyres being low on tread, new tyres fixed it straight away.
Sounds like you need a wheel alignment anyway.
- lozz
hi gumby
grab the top of the wheel 12oclock pull it if you feel any play, top have links failed,
always check the top links with the weight of the car on its wheels not with it jacked up,
took me ages to find out the top links where knackerd on mine, even mot tester said they was ok,
because they where checked with the car raised,
Thanks for the info gents, I'll check for play on the rear wheels later. Clearly I need wheel alignment at the front and hopefully no work on the rears - fingers crossed
Hi
Since you can track all 4 wheels on the 406 ( It cost me £ 40 recently ), I would suggest that you change the rear droplinks ( £20 or cheaper on the bay of e ) first anyway.
Then get all 4 wheels tracked
Don't worry, rear drop links won't affect the rear track
But it might be a good idea just to do them while you're in there anyway....
On mine, it was the lower rose joint bushes. Felt like it had rear steering or something
Pray it isn't that, as the job is a bit of a bitch! Use Motaquip or other reputable parts where you can, they're very good quality and reasonably priced on ebay. Generic pattern parts like drop links and suspension bushes are often of poor quality, then you're out there doing the same job again before you know it.
- OdinEidolon
It has!ally406 wrote:Felt like it had rear steering or something
Well, not steering, but 406's wheel turn a little under strong force. Also 306 and Xantia have this feature.
'Passive' rear wheel steering.
I thank yaw
I thank yaw
- OdinEidolon
It's great tech, isn't it. You can definitely feel it on tight U bends like the ones we have here on the mountains.Welly wrote:'Passive' rear wheel steering.
I thank yaw
You might be able to feel it but are roads are so spectacularly poor the whole of the suspension has be smashed so much that even the fronts have passive steeringOdinEidolon wrote:You can definitely feel it on tight U bends like the ones we have here on the mountains.
- OdinEidolon
You have so bad roads there? Here they aren't bad, generally.Welly wrote:You might be able to feel it but are roads are so spectacularly poor the whole of the suspension has be smashed so much that even the fronts have passive steeringOdinEidolon wrote:You can definitely feel it on tight U bends like the ones we have here on the mountains.
I didn't realise this, but thinking on it, I could see how the whole hub could pivot one way or another with strong force. The bushes on mine were so bad you got this effect just turning out of the drive way. You can also add the 405 onto that list incidentally!OdinEidolon wrote:It has!ally406 wrote:Felt like it had rear steering or something
- OdinEidolon
Yep, and also some more cars from Peugeot and Citroen. Also some other manifacturers did it, while some others really have rear steering, like the Laguna has.ally406 wrote:I didn't realise this, but thinking on it, I could see how the whole hub could pivot one way or another with strong force. The bushes on mine were so bad you got this effect just turning out of the drive way. You can also add the 405 onto that list incidentally!OdinEidolon wrote:It has!ally406 wrote:Felt like it had rear steering or something
- mjb
- Site Admin
That's not rear wheel steering on the Laguna - that'll just be the play in all the bolts they forgot to tighten...OdinEidolon wrote:Yep, and also some more cars from Peugeot and Citroen. Also some other manifacturers did it, while some others really have rear steering, like the Laguna has.
- OdinEidolon
mjb wrote:That's not rear wheel steering on the Laguna - that'll just be the play in all the bolts they forgot to tighten...OdinEidolon wrote:Yep, and also some more cars from Peugeot and Citroen. Also some other manifacturers did it, while some others really have rear steering, like the Laguna has.
Don't joke on it, my mum's clio rear brakes (drums) did make contact even when not braking just after having bought the car. "Normal" listening to the Renualt dealer.
