3 inch lowered springs 406 1.8i 1998
gordonw
Post by gordonw »
Is it possible to fit 3 inch lowered springs with the standard shockers,got a broken spring a been offered the springs as a freebie and will need to strip the suspension down to replace some worn links etc so if these would fit i would stick them on. :cheesy:
1997 D8 1.8I STILL GOIN!
1996 MERC C200 ONGOIN PROJECT HONEST!
1995 ESCORT DIESEL VAN
2009 DAF XF 105 460BHP
THE PARTY AINT OVER YET !!
plod
Re: 3 inch lowered springs 406 1.8i 1998
Post by plod »
I believe 40mm is the lowest drop you can do with the standard shockers so 3" (75mm) is too much i'm afraid
1999 D8.5 HDi GLX - Sold :(
gordonw
Post by gordonw »
Thanks Plod,didnt think i had enough travel on the standard shockers just checking.
75mm lower ? really ?
you must have a lot of money to keep replacing exhaust when it keeps getting ripped off :cheesy:
if you live in area with no speed humps bad holes in road etc, you can get away with having them low,
ihad a fiat that ilowerd and ended up driving over speed humps at an angle or it wouid get caught up on the undertray :lol:
it was fun while it lasted,
adjustable coil overs are the way to go ithink :roll:
Hangar18
Post by Hangar18 »
3 I N C H E S!!??
I rub speed bumps standard!!
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
