3 inch lowered springs 406 1.8i 1998
Posted: Sun Dec 11, 2011 3:53 pm
by gordonw
Is it possible to fit 3 inch lowered springs with the standard shockers,got a broken spring a been offered the springs as a freebie and will need to strip the suspension down to replace some worn links etc so if these would fit i would stick them on. :cheesy:
Re: 3 inch lowered springs 406 1.8i 1998
Posted: Sun Dec 11, 2011 4:00 pm
by plod
I believe 40mm is the lowest drop you can do with the standard shockers so 3" (75mm) is too much i'm afraid
Posted: Sun Dec 11, 2011 4:07 pm
by gordonw
Thanks Plod,didnt think i had enough travel on the standard shockers just checking.
Posted: Thu Dec 15, 2011 8:44 am
by Gary406
75mm lower ? really ?
you must have a lot of money to keep replacing exhaust when it keeps getting ripped off :cheesy:
Posted: Thu Dec 15, 2011 5:23 pm
by lozz
if you live in area with no speed humps bad holes in road etc, you can get away with having them low,
ihad a fiat that ilowerd and ended up driving over speed humps at an angle or it wouid get caught up on the undertray :lol:
it was fun while it lasted,
adjustable coil overs are the way to go ithink :roll:
Posted: Mon Dec 19, 2011 4:59 pm
by Hangar18
3 I N C H E S!!??
I rub speed bumps standard!!
