Hoggars
Hoggars
I have a 2003 Executive Estate and it has 16" Hoggars fitted,i think that's what they are called,i see coupes are fitted with the same design wheels,would they be the same as fitted to my car? i was looking at picking some up sometime so as to give me an alloy spare and to be able to fit winter tyres to a couple.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
- highlander
- PowerFlow Shill
Re: Hoggars
I seem to recall that the offset is different between the Coupe and Saloon/Estate models, so there are actually two variants of 16" Hoggar alloy, the only difference being the offset.
Hoggars look nice, but the fact that they are centreless alloys is a MAJOR pain in the ass when trying to get them balanced - some tyre places will flat-out refuse to even try, others will try and find their kit can't do the job, leaving comparatively few places that have the right kit and the knowledge to be able to do it properly.
Re: Hoggars
Never thought of that but just had a look at one and as you say they have no centres.
Re: Hoggars
thats the reason i got rid of my V6 alloys and got the 16" vulcans
- OdinEidolon
Re: Hoggars
I actually thought they had the same exact offset - I may be wrong tho. V6 starfish alloys were present on the saloon too I think.highlander wrote:I seem to recall that the offset is different between the Coupe and Saloon/Estate models, so there are actually two variants of 16" Hoggar alloy, the only difference being the offset.
Re: Hoggars
I have a set of 16'' Hoggars (saloon offset) 3 are in good condition, one is scratched but not damaged - ideal for winter tyres.
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
Re: Hoggars
How much you looking for?
Re: Hoggars
£75 2 tyres i think are ok, the other 2 are borderline legal. The only reason I am not running them is because I fitted brembo brakes and they wont clear them - so had to fit 17s in a hurry.
- waue1978
- HDi don't believe it!
Re: Hoggars
Myself & 406loon confirmed this between us when he found his Hoggars didn't accommodate Brembo calipers. Further investigation found that his saloon Hoggars had a 20mm offset while my coupe set are a 12mm.OdinEidolon wrote:I actually thought they had the same exact offset - I may be wrong tho. V6 starfish alloys were present on the saloon too I think.highlander wrote:I seem to recall that the offset is different between the Coupe and Saloon/Estate models, so there are actually two variants of 16" Hoggar alloy, the only difference being the offset.
I was under the impression that the Vulcans had the same mounting? One of the things I liked abouth my Nautilus wheels was that they have a proper mounting face on them, but if the Vulcans are the same, I much prefer the look of them.Gary406 wrote:thats the reason i got rid of my V6 alloys and got the 16" vulcans
