Will an offset of et42 fit a D9 hdi?? They're 17" if that helps.
cheers
wheel offset
Re: wheel offset
406s are around ET15-ET20 .
waue1978 will tell you properly . hes the guy to see about wheels on here
- waue1978
- HDi don't believe it!
Re: wheel offset
Not without massive (20mm+) spacers. On 7ins wide wheels, I wouldn't go more than 20mm offset otherwise there'll be rubbing issues.ashgtir wrote:Will an offset of et42 fit a D9 hdi?? They're 17" if that helps.
cheers
Re: wheel offset
Ok then cheers. guess ill keep searching for a set of 17"s
