[SOLVED] Tyre pressure for D9 V6 saloon
I recently became the lucky owner of a 1999 D9 saloon (but with the old V6 engine). The problem I have is that the manual makes no mention of tyre pressure, and the label on the front door is missing. Could someone who has a similar spec car please take a picture of the label and upload it?
- jonsowman
Re: Tyre pressure for D9 V6 saloon
If it's the same as the D8 saloons then 33psi.
OT but D9 406s with the D8 engines must be pretty rare? Sounds cool, I bet a lot of people would like a D9 with the 1.9 XUD.
Thank you. I was hoping for a picture of the actual label, because usually the recommended pressure also depends on speed range, loading, and tyre dimensions (in my case 205/60R15).
I can't tell how rare it is, but I have seen a few of them for sale around here (not UK). I'm guessing that cars delivered in '99 and possibly 2000 had the old engine. Judging by for-sale pictures 2002 cars had the new engine.
- mjb
- Site Admin
I think 34psi all round is the "correct" pressure, but I usually go for 35psi front and vary the rears from 33psi in snow/ice to 37psi for long cruises in the summer (makes a hell of a difference to fuel economy!).
Your talking 37psi for a boot full of camping gear aint you? does it really make that much difference in fuel?mjb wrote:I think 34psi all round is the "correct" pressure, but I usually go for 35psi front and vary the rears from 33psi in snow/ice to 37psi for long cruises in the summer (makes a hell of a difference to fuel economy!).
Found it! Turns out the label wasn't missing after all, just smaller and not quite where I expected it to be.
Correct pressure for my variant is 2.3 bar (a bit over 33psi), 2.5 bar (a bit over 36psi) loaded.
- mjb
- Site Admin
Camping gear or not it makes a huge difference. Not too long ago I drove to Cornwall and back with an empty car on 33psi and managed about 30mpg. With a fully loaded car pumped to 37psi I can do 50mpg on a good run.scotty73 wrote:Your talking 37psi for a boot full of camping gear aint you? does it really make that much difference in fuel?
Re: [SOLVED] Tyre pressure for D9 V6 saloon
My V6 was ordered just before the new engine was announced and was delivered in April 2000 so that should give you a rough reference point for the engine changeover.
2000 406 GTX V6 auto 210hp
