rear brakes only working 10%
Posted: Thu Apr 26, 2012 5:27 pm
by omega
thought the brakes wernt as sharp as they useully are so done a bit of a looking before rain stopped play and the rear brakes arent doing much.with the pedal pressed i can still turn both wheels by hand!!the pads look good and the calipers are moving gripping the disc and freeing off so any ideas?
i should add that i havnt done any work on the brake system so cant see it being air in the system, brake fluid is clean no leaks,if the caliper was seized it wouldnt work at all so is there anything in common with both sides?
oh yes its a d8 model with discs and the handrake shoes inside the drum.
Re: rear brakes only working 10%
Posted: Thu Apr 26, 2012 5:43 pm
by Bailes1992
replace the brake fluid and refurb the rear calipers would be my first port of call.
Posted: Thu Apr 26, 2012 5:44 pm
omega wrote:if the caliper was seized it wouldnt work at all
Probably the sliding pins are seized: if so the caliper is pushing the inner pad against the disk but the caliper isn't sliding over to pull the outer pad onto the disk, so it's bending the disk instead :shock:
I'm sure it'll all become clear once you pull it to pieces...
Hmm, I can't remember if yours is a saloon or an estate, I think saloon but the estate also has a load valve on the rear beam axle which could break.
Posted: Thu Apr 26, 2012 5:48 pm
by lozz
not sure on the d8s but,
iirc the 405s had a compensator for the rear brakes,and if the spring broke, the rear brakes went crap,
iwonder if the early d8s have the spring and compensator :roll:
Posted: Thu Apr 26, 2012 5:53 pm
by lozz
according to this it has one,
bottom of the page on the Recalls list
link http://www.autotrader.co.uk/articles/20 ... ying-guide
Posted: Sat May 19, 2012 12:16 am
by omega
well had a look today and the piston in the caliper is working but i think this is a sliiding caliper and the other side isnt sliding so
can you split the caliper down on the car so i dont have to bleed it all when i have finished?
what do i undo to split it?
whats the best stuff to use to make it slide i was thinking some high temp grease
Posted: Sat May 19, 2012 6:30 pm
by lozz
Ithink you wouid have un-do the metal brake pipe (icouid be wrong tho)
iuse copper grease on pad backings/sliders etc,
Posted: Sat May 19, 2012 11:03 pm
by jasper5
omega wrote:well had a look today and the piston in the caliper is working but i think this is a sliiding caliper and the other side isnt sliding so
Don't split the caliper, you will end up replacing it!!
Free off all the sliders and pads.
Posted: Sun Oct 14, 2012 1:28 pm
by Kiwi
lozz wrote:according to this it has one,
I have a similar problem with my 2000 Hdi 110 estate. I just looked on the quoted link and only found this at the top of the 406 recall list ; " August 1997 – Setting of brake compensator. 333 cars affected " . Is there any way to check recalls against the VIN # ? Thanks.
Posted: Sun Oct 14, 2012 3:40 pm
by jasper5
All recalls are listed on the VOSA site, all vehicles and makes.
http://www.vosa.gov.uk/vosa/apps/recall ... search.asp
Posted: Sun Oct 14, 2012 6:36 pm
by Kiwi
Many thanks jasper5
Posted: Sun Oct 14, 2012 7:37 pm
by madmadmax
get sum new sliders
http://www.ebay.co.uk/itm/Peugeot-406-6 ... 3f1cb9e86d
thay should fit but check first
Posted: Sun Oct 14, 2012 8:07 pm
by Kiwi
madmadmax wrote:get sum new sliders
Thanks, I put a new set on one side 2 years ago and lubed the other at the same time . When I checked temperatures, both rears were cold, even though they are polished.
I can't put it off any longer, have to take a look and check .
Posted: Wed Oct 24, 2012 2:45 pm
by Kiwi
Eats humble pie ....................sliders seized on one side, pads seized in housing on the other. All bolts had been liberally coated with a copper anti-seize, sliders packed with moly CV grease.
Will put on " to check " maintenance list. Also found it has no load sensing valve in rear brake circuit.
