Anyideas,here chaps
Ive had ago at sorting the Brakes out on a suzuki weve got sat in the garage,
was thinking of putting it back on the Road for little while, instead of using the fiat which im not impressed with,
the problem is the brakes are only working on 3 corners,
the front passenger side one is doing nothing,
ive bled all of them and theres nothing coming out of the front N/s caliper
ive checked to see if its seized but it Moves freely, ive only spent 20mins on it and gave up, lost for ideas as what to try next,
Any ideas,
the car is a 01 reg Zuki alto, 998 cc,
Not 406 related, again sorry,
- lozz
Re: Not 406 related, again sorry,
If there's nothing going through the line then I guess it must be blocked. Try splitting it at the flexible pipe to see if something comes out there, if not look for damage to the metal section
- lozz
Cheers steve,
iwill give that a Try,
At 1st ithought Master cylinder, but with there being preasure at the other 3 corners - its looking fixable .
i had this once and was told to remove the nipple and leave it over night!
tried it and it worked!
- lozz
Ive tried everything still nothing,
took the pipes off one at a time, right up to the Master cylinder and nothing coming out of there,
only getting preasure for the 3 other corners,
looks like Master cylinder is fubard iguess,
- lozz
just orderd a caliper and a Master cylinder off ebhay,
Secound hand ones, No where on the planet seems to sell parts for this car new ones anyway,
inoticed the Master cylinder on it is Made in india so iguess that says alot,
nowt else to try after that, if that dont work iguess its going on the scales
