Uneven Rear Tyre Wear
Posted: Wed May 08, 2013 11:52 pm
by jonsowman
Just had a quick look round the car, and noticed that the inside of the rear nearside tyre is completely worn down, barely any tread left! Outside of said tyre is fine, several mm of tread. Tyres are about 2-3 years old (Bridgestone Turanzas).
Now, what's likely to be the cause? Should I be suspecting track arms? Is four wheel alignment the way to go here?
Going to have to replace the tyre either way, that'll teach me to rotate them more regularly!
Re: Uneven Rear Tyre Wear
Posted: Thu May 09, 2013 7:15 am
by Ares
i have the same problem, the thing is that my outer part of tyre is worned down,opposite of yours.
when i grab with my hands and start shaking the tyre it feels like its bumping something inside
Posted: Thu May 09, 2013 8:31 am
by dummysock
replace top links both sides and then 4 wheel laser wheel alignment.
I try to use good quality top links because tracking is £50 and you don't want to pay for this too often
Posted: Thu May 09, 2013 10:07 am
by jonsowman
Thanks guys - any recommendations of where to get 4 wheel alignment done? £50 sounds acceptable.
