Brake pedal pulsation
Posted: Mon Jun 17, 2013 11:15 pm
by Samir
Hi there, I used to have an intermittent pulsation on my brake pedal when braking at low speed , I changed all my discs and pads but the problem got worse, the pulsation got worse and I started having some squeaky noise when braking, my mechanic suggested the cheap parts I bought online from euro car parts were the cause, at this point I decided to buy a better quality front discs and pads (in case the discs were warped) ,,,,unfortunately this didn't fix the problem either. I don't know if I should change the rear discs and pads as well or this is going to be money down the drain again
Can anyone advise please?
Could this be the abs /abs sensors/ or simply the rear discs.
As I said its a frequent pulsation on pedal at low speed (below 40m/h)
Any help would be appreciated.
Re: Brake pedal pulsation
Posted: Tue Jun 18, 2013 9:03 am
by Ares
Hi Samir,welcome to the show
i would mind about that sqeaking sound,thats just some pads doing,mine is sqeaking too.
about that pulsation,dont know,you did change discs,pads,so that is not problem,perhaps brake fluid and pipes?
Posted: Tue Jun 18, 2013 10:05 am
by teamster1975
Welcome Samir!
When you fitted the new pads did they slide freely into the caliper or were they a tight fit?
On some pads they have "hrns" on the top that need filing down to allow the pads to slide freely; also make sure you give the calipers a damn good clean and smear some copper grease on the back of the pads.
Re the squeal; you can minimise this by filing a chamfer around the face edges of the pads.
Posted: Tue Jun 18, 2013 10:15 am
by puggy
look for abs ring in the search box , think you will find that one of
them has split .
Posted: Tue Jun 18, 2013 7:47 pm
by hammerman
Over the 7 years I`ve had my 406,i sometimes get the pulsating pedal at slow speed.Normally after a few days or a week or so the abs light will come on and the pulsating goes away.Its normally the abs ring on the cv joints or rear hubs,or a abs sensor.
Posted: Wed Jun 19, 2013 7:22 pm
by jasper5
Puggy has a sensible suggestion, take a look here....
viewtopic.php?f=10&t=15234
Posted: Sat Jun 22, 2013 12:40 am
by Samir
hammerman wrote:Over the 7 years I`ve had my 406,i sometimes get the pulsating pedal at slow speed.Normally after a few days or a week or so the abs light will come on and the pulsating goes away.Its normally the abs ring on the cv joints or rear hubs,or a abs sensor.
Thank you all for your suggestions , I have just come back from Wales and the brakes were fine on high speed, still the same problem when driving slowly though, I am popping to my friends garage to check out the abs ring and sensors and I wil keep you updated.
