Anti roll bar size
Anti roll bar size
I need to order/buy some front anti roll bar mounting bushes.But everywhere I look,i`m asked what size diameter.23mm or 24mm.Does anyone know?Car is a 2003/53 hdi 110 estate.
2003 Hdi Est SE
Re: Anti roll bar size
According to servicebox, mine is defo 24 mm, also lists 24mm for 110 HDi estates, whether std or heavy duty suspension.
It has been known to be wrong tho.
I checked mine (before I saw your reply
) and SB says 24mm. However, as the man said, Service Box isn't always trustworthy, if you have a micrometer or vernier give it a measure
24mm on mine.Replaced them at the weekend.The r/h/side was gone,omly about 50% of the bush left
The left was better at around 75%.Easy enough to change but it took ages to remove the old bushes as the were stuck fast on the a r bar,and not the best access to get a screwdriver on the to hammer them off.Also changed the bottom ball joints.Again,easy enough to do.I got the socket off ebay for around £7.50 & used my 3/4" drive socket set with a 3ft tube on the end.They were tight to remove but came off easy enough.
I thought it would make a difference to the car but hard to tell
.Never mind though.Thats all the suspension & bushes done now.
2003 Hdi Est SE
