1998 406 Break 1.8 16v
The rear mounting bush on my left hand front lower control arm has worn out and is causing noise.
Parts here are very expensive so I have taken to ebay for a replacement.
I found this http://www.ebay.co.uk/itm/Peugeot-406-F ... 416ca6b8e8
Can any one tell me if this is the right part and if it just slips over the end of the arm and bolts down or do I need some special tool to fit it.
The haynes manual is essentially useless on this but looking at the car it visualy looks like if I just remove the two mounting bolts it will slip off the end of the arm and the new one will slip on.
Lower control arm bush
- midsmike
Re: Lower control arm bush
Yes that's the right one but it can be hard to get the old 1 off
- 1.6 8v
I suppose warming it up with a blow torch should aid in removal?
- 1.6 8v
Thanks for that.
I have used that procedure before, the only thing I would do different to that video is when hammering the new one on I would hever hammer directly on the end of it like that.
The risk is too high of the hammer hitting off center and damaging the new bushing, I would always put a piece of wood on the end of the bushing and hit that, then there is no risk of damage
