rear anti roll bar mount bolts snapped
Hi all just been doing the rera anti roll bar bush but found 1 of them had been snapped before & replaced with a upwards facing bolt & guess what it snapped ;-((( . How hav u guys sorted this bother as the nut looks like its hidden inside the chassis. Cut the body or floor ???????
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
- markw
Re: rear anti roll bar mount bolts snapped
Don't know what access is like Brian, but could it be drilled out and re-tapped?
Someone had a similar problem (with a sub frame bolt) on their Coupe and they had to cut open the frame rail, weld the nut down and weld up the rail again. Not easy.
