Urgent help required regarding Rear Caliper
Posted: Sun Jul 21, 2013 12:22 pm
Hi, the rear disks on my 52 plate 406tdi have been scored and will fail the MOT. I have got new disks and pads. The disk fitted fine, but the outer pad wont fit. When I took the old pad out I had to prise it as it was tight against the disk (hence the scoring).
It appears as if the whole calliper needs to move a few mm outboard.
If anybody knows the fix for this I would be very grateful as can't drive anywhere at the moment with half done brakes!!
