This if my first post so apologies for diving straight in to the technical stuff, but I was wondering if anyone could help me with the standard steel wheel bolt dimensions for a 406?
I am fitting some steels with winter tyres to our car which came with alloys as standard. I know that they will need to be m12 x 1.25 and I found a thread by searching which suggests a 60 degree taper. Is this correct?
Does anyone know the length of the standard bolts?
406 Steel Wheel Bolts Dimensions
- lozz
Re: 406 Steel Wheel Bolts Dimensions
Hi ithink they are M12 x 1.25mm (60 deg taper)
imight be wrong tho,
