diffrence in drive shafts
Hi all i have a 406 2.2 hdi and need a new (second hand) drive shaft are all hdi one the same or do i need a specific one for my car many thanks in advance Paul
Re: diffrence in drive shafts
Looks like anything with a ML5T or C gearbox will do:
- INJECTION ES9J4 AND BVM ML5T
- INJECTION EW12J4 AND BVM ML5T
- INJECTION ES9J4S AND BVM ML5T
- DW10ATED TURBO DIESEL AND BVM ML5T
- DW12TED4 TURBO DIESEL AND BVM ML5T
- DW12TED4 TURBO DIESEL AND ML5C MANUAL GEARBOX
- DW10ATED TURBO DIESEL PARTICLE FILTER AND BVM ML5T
- INJECTION EW12J4 AND ML5C MANUAL GEARBOX
- INJECTION ES9J4S AND ML5C MANUAL GEARBOX
- DW10ATED TURBO DIESEL AND ML5C MANUAL GEARBOX
- DW10ATED TURBO DIESEL PARTICLE FILTER AND ML5C MANUAL GEARBOX
Obviously not a 2.0 HDi 90 or a D8 because it'll have the wrong number of teeth on the reluctor ring
So would one off a 2.0 110 fit correctly thanks paul
- Captain Jack
Uhhh well.... No. I replaced the bottom mount on my 406 and there are, as far as I can tell, three different types on the mounting bracket, through which the drive shaft goes. I fit a slightly different one and the shafts wouldn't go through them... so I'd be very careful in picking the correct one.
Ah right its the passenger side one that needs replacing and if in ring it does not go thru the engine mount i maybe wrong tho
Is the difference in the drive shafts or the bracket? Service Box is saying there's lots of different brackets but if the driveshafts are the same then I wouldn't have thought it would matter. Or would it?Captain Jack wrote:Uhhh well.... No. I replaced the bottom mount on my 406 and there are, as far as I can tell, three different types on the mounting bracket, through which the drive shaft goes. I fit a slightly different one and the shafts wouldn't go through them... so I'd be very careful in picking the correct one.
If that's the same side the gearbox is on then it's the short one and doesn't go through the bracket.tonko007 wrote:Ah right its the passenger side one that needs replacing and if in ring it does not go thru the engine mount i maybe wrong tho
Try Ade the coupe breaker. http://www.ebay.in/itm/PEUGEOT-406-COUP ... 0451568508
