Page 1 of 2
Steering doesn't like water
Posted: Wed May 28, 2014 7:29 am
by gtv
Hi folks,I have a bit of a strange on here, I have noticed that when it has been raining and there is alot of standing water around that sometimes my steering goes heavy, once the car have dried up its fine again, now I am guessing water is getting into a connector somewhere but I have no idea where, I have checked the power steering fluid and thats all ok. Car is a 1998 D8 2.1TD I have looked at the haynes book of lies and I couldn't see anything to do with electrics for the power steering.
Thanks for any help you can give.
Re: Steering doesn't like water
Posted: Wed May 28, 2014 9:03 am
...I couldn't see anything to do with electrics for the power steering.
It might do if it has variable power steering. Not sure how you tell just by looking, maybe a vin to check it on Service Box?
Posted: Wed May 28, 2014 9:14 am
by gtv
Thanks for the reply. I don't think the d8 do.
Posted: Wed May 28, 2014 9:27 am
by markw
Water finding it's way onto the aux belt making it lose friction for a bit? That would stop/slow down the power steering pump till it dried off again..... :?:
If it's electrically variable, it'll have one of these little valves on the rack. These can be cylindrical or square.
This view is from underneath looking up.
Posted: Wed May 28, 2014 9:54 am
markw wrote:Water finding it's way onto the aux belt making it lose friction for a bit? That would stop/slow down the power steering pump till it dried off again..... :?:
That's a good point, especially if it doesn't have an undertray.
gtv wrote:I don't think the d8 do.
Yeah they do, even high-end 2.1tds were so cursed.
Posted: Wed May 28, 2014 10:04 am
by gtv
Thanks for that. I will get underneath it and check. I don't think it's the belt I have tried and it seems ok and I have tried with everything turned on to see if it loafs up the alternator and it still worked ok.
Posted: Wed May 28, 2014 10:33 am
by markw
If it's the electrically variable type and is the same type as fitted to the V6, I made up a test loom which enables you to break into the live circuit and see what's going on. You just unplug the servo controller and plug the loom in it's place.
That's how I was able to diagnose a partially functioning valve on my rack....it would have been very hit n' miss otherwise.
I'd happily post it out to you if it'd help.
Posted: Wed May 28, 2014 10:38 am
by gtv
That would be great if you don't mind :)
Posted: Wed May 28, 2014 10:45 am
by markw
See if it's got one of these first....(this is the power steering ecu believe it or not)
It's fitted up behind the glovebox....
If it has, I'll send you this!(minus the multimeter.....)
Posted: Wed May 28, 2014 12:20 pm
by PeterN
I would go with water on the drive belt.
Posted: Wed May 28, 2014 12:51 pm
by Doggy
markw wrote:Image
Mighty impressive, Mark. 8)
I'm awarding you 9.9 improvisation points out of a possible 10
(Would have been a maximum were it not for the stick-on cable tie bases, [you know they'll fall off, just not exactly when])
Posted: Wed May 28, 2014 1:30 pm
by markw
Haha ...got you on that one....they're screwed down with a half inch self tapper through the middle! :supafrisk: That piece of mdf will break before they come off! :roll: :P
"Dix points?"
Posted: Wed May 28, 2014 3:26 pm
I'm afraid I'm deducting two points for the careless use of a document 'pouch' where the instructions (although typed) would have been better laminated Image
Posted: Wed May 28, 2014 3:29 pm
Seems fine to me, then I don't have a laminator either :roll:
Posted: Wed May 28, 2014 4:14 pm
steve_earwig wrote:Seems fine to me, then I don't have a laminator either :roll:
We have the WH Smith wait-o-laminator MKII, it's like watching continental drift in slow motion..........
I was only joking, Mark has done an excellent job there, there aint no denying that.
