Rear ARB bushes
Rear ARB bushes
Hi guys long time since I had to visit the forum as the old girl has been doing grand. Lately its been making plenty of knocking noises from the rear so after a little look ive found that the drop links arent in great nik and also the arb bushes look to be in a poor state. it looks to be a fairly simple job to replace the arb bushes only I cant see one of the bolts on the drivers side as its blocked by the fuel filler duct. Ive searched other threads and everyone is just saying to move the duct out of the way but nobody gives instructions on how to free the duct. Has anybody here done this job before and have any advice for me on getting access to the hidden bolt?
Re: Rear ARB bushes
Yes I think that it the only way, to disconnect and lower the filler neck. It has been spoken about before but I'm not sure if there's any how-to's as such.......anyone??
Re: Rear ARB bushes
started tackling this job today and what a pain in the arse it truly is
getting the fuel duct out of the way is easy enough, just undo the metal clip holding it to the fuel tank and pull the duct to separate it from the tank. then just undo the plastic clips the hold the two smaller fuel pipes to the main duct and hey presto access is granted. Problem is the fracking bolt and nut holding the bush on. The nut came off without much hassle but the bolt started to come out easily and then just refused to budge either back in or out. Anyway the damn thing sheared off in the end up and to top it all off I couldnt replace the damn clip that holds the filler duct to the fuel tank (those damn annoying clips I dont know why peugeot use them everywhere) so after kicking some of my tools around the driveway I had to call a mechanic buddy who has the gear to extract the bolt.
I had a rreal bad feeling when I started this job especially when I looked at the rusty bolts and thought to myself this would be much safer to do with an impact wrench
does anyone know what the trick is to getting those steel clips attached?
Re: Rear ARB bushes
Yeah I have a pair of clip pliers but you can use nail pincerskeppler wrote:started tackling this job today and what a pain in the arse it truly isgetting the fuel duct out of the way is easy enough, just undo the metal clip holding it to the fuel tank and pull the duct to separate it from the tank. then just undo the plastic clips the hold the two smaller fuel pipes to the main duct and hey presto access is granted. Problem is the fracking bolt and nut holding the bush on. The nut came off without much hassle but the bolt started to come out easily and then just refused to budge either back in or out. Anyway the damn thing sheared off in the end up and to top it all off I couldnt replace the damn clip that holds the filler duct to the fuel tank (those damn annoying clips I dont know why peugeot use them everywhere) so after kicking some of my tools around the driveway I had to call a mechanic buddy who has the gear to extract the bolt.
I had a rreal bad feeling when I started this job especially when I looked at the rusty bolts and thought to myself this would be much safer to do with an impact wrench![]()
2006 BMW e61 535d m-sport
run's for cover
Re: Rear ARB bushes
Cheers ddd, I just did a little research and found that they're called clic-r clips . It looks like a pair of tying wire knips would do the job nicely. I only had a short stubby pair and they just wouldn't work at all
Re: Rear ARB bushes
I use the a pair of cheap wire strippers, look for something with a narrow tip and decent length handle.
Wire strippers work a treat on CV boot clips as well.
Re: Rear ARB bushes
cheers for the tip gumby,
Anyway took the car to my mate and he drilled the bolt out and we both set about doing the rest of the job. Gotta say having an impact wrench makes a world of difference. didn't even need to use any wd40, the gun just vibrates the nut loose
The car now feels like it has a brand new suspension and glides over the bumps plus my mate manged to convince me to buy his old compressor from him so I'm now in the market for an impact wrench
Just in case anyone is wondering, the old bushes looked to be in ok condition (it has passed its last two NCT's without so much as a warning about them) however when they were removed it became clear that they were done for, dry, hard and brittle. The car is a 2000 reg and I think its safe to assume they were the original arb's from the factory.
