OK, Was going to get the steering pump replaced before the clutch went, now this is done I wanted to confirm that this is the likley cause?
Basicly, the steering suddenly goes heavy. you will turn to the right and it will be nice an light for a quarter turn, then it will be heavy then light again. turning left, its heavier then it is normally. So basicly when you are sat a junction it can make for some interesting manuaovers as you have to compensate, and then sometimes over compensate.
Dose this sound like the power steering pump?
Steering pump replacement
2002 2.0l HDI 90BHP 406 Estate.
Re: Steering pump replacement
Sounds like a loss of hydraulic pressure, could be the pump, or an air leak, or the belt slipping.
Could also be the strut top bearings...... it gives the car a 'lumpy' steering.
