wheel bolt wont go in
annie
Re: wheel bolt wont go in
Post by annie »
right down on the south coast im afraid. thanks anyway.
stevewalsh
Post by stevewalsh »
If the thread is damaged on the wheel side of the hub, try putting the bolt in from the back with plenty of lube, such as wd40, it might clean up the existing threads.
I wouldnt use loctite to hold it in, you will sruggle with it next time it has to come off and you maybee on the roadside with a puncture
Steve
annie
Post by annie »
bloody brilliant idea coming from the back. will check it out later.. thanks
jasper5
Post by jasper5 »
stevewalsh wrote:If the thread is damaged on the wheel side of the hub, try putting the bolt in from the back with plenty of lube, such as wd40, it might clean up the existing threads.
Steve
You will need to remove the disc and caliper to do this, plus you risk stripping out the threads completely.
Loctite will not stop you undoing the bolt.
jasper5
Post by jasper5 »
Just had a thought about this....I have assumed all along that this wheel bolt is on a front wheel....is this correct?
On the rear it is quite easy to replace the hub as they come complete with the wheel bearing.
annie
Post by annie »
yes front wheel. doing rear drop links later so will look at this wheel bolt again, if not will order stuff today and try and retap in week
annie
Post by annie »
fixed it. tapped it out and fitted new bolt.
tap £5 and peugeot bolt £3. took 30secs to tap out so great result,way better than changing the hub and bearing.
jasper5
Post by jasper5 »
annie wrote:fixed it. tapped it out and fitted new bolt.
Well done :cheesy:
Good result :D
gumby6371
Post by gumby6371 »
Always nice when the fix is so easy, I suspect someone was a bit too quick with the air gun in the past.
annie
Post by annie »
it could have been a few hundred so very pleased.
still those awful rear droplinks. ordered 406 haynes so will look at manual and then prob take to local garage.
