leather seats
- Newbie
leather seats
Has anyone ever tried fitting electric leather seats till a td non leather manual seat 406 ?
Re: leather seats
Yes, there's a host of information on here - just use the search facility. There is how to do stuff in the knowledge base that goes through step by step bypassing drivers seat ecu - passengers seat is straightforward. The hard bit is tracking down a good set of seats in the first place! I found the actual conversion relatively easy but had done a lot of reading on here first. Some good you tube videos as well - shows good hints at stripping out interior and seat removal and suchlike. If you get to strip everything out of a scrapper then get as much of the wiring harness as you can including heated seat switches etc.Good luck! Regards, Geoff.travers wrote:Has anyone ever tried fitting electric leather seats till a td non leather manual seat 406 ?
2003 2.2 HDi 136 Exec estate.
- peo
Re: leather seats
Yes, it's possible to convert from 406 sr version to leather version seats but is really useful someone with electronic skills.
I mounted electrical and heated leather seats but with an electric friend acknowledge.
Peugeot 406 HDI SR Pack Fase II 2004 with Brembo calipers and strut force
