Dash bulbs
- 1.8 8v
Dash bulbs
does anyone know what dash bulbs are in the heater panel and clock and also does the radio screen that shows the outside tempture meant to light up in the dark when the lights are on?
thanks
thanks
- mjb
Re: Dash bulbs
Presuming it's a D8 the heater panel should be standard jobbies, but the clock and radio display need low profile bulbs which appear to be dealer only
- swiss
Re: Dash bulbs
This is true, do not put regular bulbs in yer clock or all the internals go crunch >.<
The man with no car
- 1.8 8v
Re: Dash bulbs
do you know what part numbers they are?
- plod
Re: Dash bulbs
Low profile ones from the stealer are 611256 - were £1.72+vat from my local one
1999 D8.5 HDi GLX - Sold
Bring back my 406
Re: Dash bulbs
which parts need these bulbs ? ive replaced my speedo clock bulbs before with normal ones from a factor and they seem fine ??
- plod
Re: Dash bulbs
As above, clock and MFD
Bring back my 406
- HimBigChief
Re: Dash bulbs
Multi Function Display, the bit on the dash that displays the external temp and radio station, etc.
Re: Dash bulbs
ok thanks, so speedo clocks are ok with normal buls then
- swiss
Re: Dash bulbs
Yup
The man with no car
