Sloshing sound
Re: Sloshing sound
More-or-less the same place, if you found the front ones you should know what you were looking for - feel along the inside of the flange for it. I tired taking pics while I was there but the sun was too bright and none of the pics show anything useful.
Re: Sloshing sound
i took the wheel off, the wheel arch liner, shitting myself that there would be rust like the breaker car coating all behind the liner, but no its like new in there, anyhow what isnt like ne are the sills, between being jacked up wrong and me hitting kerbs the thin strip on the end was a bit odd looking, so i beat it into a straight line, then stupidly drilled a hole beside the drain hole. Then found the drain hole which had some gunk holding it up, then the sill drained out. I left it for 10 minuites, went and got the waxoyl but i found the sprayer and its broke.
Do i just spray through that cap in the wheelarch, if i take it out will it go back in. And the time i changed the sill seals i sprayed a shitload of waxoyl into the wee holes, probably explains the gunge will it be ok to put more on top of it.
