Peugeot 406 - did it have Webasto as an optional?
- lozz
Re: Peugeot 406 - did it have Webasto as an optional?
excellent info there steve,
- OdinEidolon
If one gets it from Peugeot should expect to pay for it for his entire lifetime...
I can't tell which was fitted to what and whether these things can be found in many broken cars, the only Picasso VIN I have is for a TU engine and it won't have one.
- lozz
The haynes shows refernce, to the petrol pics having one,steve_earwig wrote:I can't tell which was fitted to what and whether these things can be found in many broken cars, the only Picasso VIN I have is for a TU engine and it won't have one.
Mines a 1.6 Tu engine and warms up pretty quick from frosty starts so ipresume it has one
Citroen Service just says EV/DV and DW10. I tried my mate's and nothing, I guess they just warm up fast
- lozz
You couid be right steve,
iwas thinking they had them because they warm up quick, but saying that they are only a little Rad so that might be the reason,
Haynes Refers to some sort of critter being located under the passenger side front wheel are liner, iwill take it off when iget chance and have a nosey,
haynes seems to abit confusing tho, derv & petrol are in seprate sections but coolant and other parts seem to be all in the same pot
- OdinEidolon
I have some more info:
krzychu.pl wrote: Webasto used did not meet the sales, can you look at the broken cars.
If you have installed Webasto, is programmed / steer him from the air conditioning panel.
You can set the time, temperature and all the rest.st.
Converter 12V/220 V,, can not be,, too high power consumption ,,300 watts. battery will discharge .
Webasto topic explored in the 406th
is one type to 406,, for all types of engines.
There are two versions of the Webasto:
Poorer - only when you turn the engine warms.
after firing the engine you already have some kind of temperature on the warm air vents flies.
Full - warm engine, the blower is additionally plugged the car, which warms the interior of the car.
Webasto runs only 30 minutes.
It must be remembered that after turning off the Webasto before restarting it should be a minimum of 30 minutes ride by car to recharge the battery.
is mounted on the back under the floor (see photo above), is connected to the water snakes of the car on a small water circulation, ie,,, Webasto / engine / heater.
Kilmatronic panel to set the desired temperature, eg 22 degrees.
Webasto and program run from a separate remote control.
Used to get and I'll look for you,
but you must have a remote control for controlling.
The cost of a new pilot in the service Peugeot 250 euros, the cost of the service webasto Peugeot find out after the weekend
But there are small costs.
Operation and Programming webasto
Webasto Manual Peugeot 406
The clock selector 24 - Webasto
Introductory Programming heater:
Warm start time can be precisely set from 1minuty to 23godz 59 min.
Duration of the inclusion of the pre-selection or immediate or heating may be 59 or 29 min.
With the right kind of connection when you start an immediate heat button it is possible to work permanent.
Appropriate type of electrical connection is marked with a cross through the installation workshop.
duration of 59 min incorporation
duration of the inclusion of 29 min
work has on the ignition (clamp 15)
work was in the position of ignition radio / garage (clamp 75)
work has a lasting connection with the plus (clamp 30)
Setting the Clock Selector
Insertion time clock
Run time of the day (tagesziet) and at the same time forward (Vorlauf> or backward Rücklauf).
Tip:
The longer the faster przebiek pressing digits on the clock.
Polling time clock
Press the time of day (Tageszeit).
Heating on / off
Press the heat immediately (Sofortheizen)
Inclusion indicator light is lit.
Heating off:
Restart the immediate heat button
Programming the beginning of heating:
Run the "1". Time preselection Vorwahlzeit
Run forward button (Vorlauf) or backward (Rücklauf) until the field appears displaying the required time.
The number 1 is displayed.
Standby indicator lights up.
The "2" allows you to set a second time preselection.
Run the "2" pre-selection time? (Vorwahlzeit)
Activating the first time pre-selection is cleared.
Activation of the second pre-selection time is displayed on the indicator number 2
Setting the second time as the pre-selection takes place for the first time.
Time control preselection:
Briefly press the "1" preselection time (vorwahlzeit) 1 or 2 times pre-selection "2".
At the rate displayed is the time pre-selection and number designation.
Deleting prefetch time.
Briefly press the "1" until the pre-selection or "2" pre-selection time
The figure marks fade and ready indicator on the display.
You can also ask for additional installation in good company "WEBASTO"
Perform such services.
http://www.webasto.it/azienda/it/html/9230.html
In Poland there are companies that offer sales and installation of Webasto heating for each car
http://www.ebac.pl/
http://allegro.pl/webasto-ogrzewanie-wo ... 01683.html
- lozz
had anosey on the petrol pics they dont have them,
someone said the pug 206 hdi have them standard dont know if thats true tho,
- lozz
http://www.myturbodiesel.com/1000q/a3b4 ... heater.htm
Worth aread
http://www.ebay.co.uk/itm/engine-pre-he ... 35b6c30ed4
http://disk.tom.ru/zfwfm8h
Needs google translator
*if anyones looking for the factory look pre-heaters the only thing ican find that will blend in under the bonnet of a 406 is the bmw 2006 preheaters but obviously they will be 12v,
theres one of them on ebay (Secound hand one,
Worth aread
- OdinEidolon
lozz wrote:http://www.myturbodiesel.com/1000q/a3b4 ... heater.htm
Worth aread
Sooo basically a pump with a resistance attached to it that fits in the engine and works out of a standard 220V plug?
For 60£ it'b be acceptable, but not more.
EDIT: anyone can find/ draw a basic scheme on how the HDi cooling system is made?
There are some diagrams in Haynes...
