Ok, Old Denty is throwing up problems like theres no tomorow.
Fault number 1056:
drivers electric window is rubbing on the trim/dooor card inner edge, pulling the bit that should be "tucked inside" the door, out in a squeal of plastic against struggling glass.
Sounds like the moror is going to cook, its struggling that hard?
Anyone suffered similar?
Be nice to know what needs replaced/fixed before I start dismantling.
Cheers all.
You guys rock.
Electric window/Trim rub.
- VND
- eoin27
- The Irish 406 addict
Re: Electric window/Trim rub.
Cheers!VND wrote:You guys rock.
Those rubbing strips can become loose and affect the eindow going up and down. Best to just get another from your scrappy.
- VND
?eoin27 wrote:Cheers!VND wrote:You guys rock.
Its the door card iself thats pulling up out of the gap.
So im guessing im missing a rbbing strip altogether?
One of my back doors was doing that, eventually the door card fell off so I investigated - the rubber strip had been put on backwards
- VND
Ha ha ha.steve_earwig wrote:One of my back doors was doing that, eventually the door card fell off so I investigated - the rubber strip had been put on backwards
Excellent.
I like your technique dude.
Think I'll perciveer with waiting for it to fall off, then investigate.
Both my front door card trims catch. It sometimes causes the window to come back down when I try to close it. I won,t wait till the door card drops off, my excuse is Im waiting for better weather
