Pulling out air vent surround
Posted: Fri Jul 23, 2010 10:31 pm
by FarmerPug
How do i go about getting out the air vent surround on the passenger side of a d9 saloon, ie where are the screws/clips holding it in place
Re: Pulling out air vent surround
Posted: Sat Jul 24, 2010 10:58 am
by HimBigChief
No screws or clips to remove, just wedge a flatblade screwdriver behind it and pop it out.
Posted: Sun Jul 25, 2010 6:24 pm
by FarmerPug
Is it possible to do this without damaging the plastic, because i find whenever i pry apart things it usually damages the plastic a bit on where i am doing it, and i dont want to have this on my cars dashboard, so would one of them plastic pry tools i have for taking apart mobile phones do the job, or is there any tips for this
Posted: Mon Jul 26, 2010 12:08 am
by chrisfinlay
my $0.02:
I had to remove the external temp display the other day, used a metal screwdriver, and there's no sign. the plastic is made of strong stuff.
Posted: Mon Jul 26, 2010 7:57 am
by Captain Jack
The vents or the surround?
For the surround, you need to undo 3 screws at the underside of the top of the speedo. Other than that, it pulls out, but there are 1000 clips holding the thing in place.
Posted: Mon Jul 26, 2010 12:55 pm
by FarmerPug
no its the air vent surround on the passenger side, is it just a clip then, i think the speedo one should be easy enough there is 2 screws at the top and one somewhere else (where?) does the steering wheel need moved for getting it out
