Tools needed to remove a rear view mirror?
no2lurch
Post by no2lurch »
What tools should I take to the tat yard to remove an auto dimming mirror?
Current car - Ph3 1.8 306
omega
Re: Tools needed to remove a rear view mirror?
Post by omega »
big hammer :cheesy:
Now that's not very helpful now is it? You'll need a crowbar.
Therer's a how to on cleaning the rain sensor here - viewtopic.php?f=10&t=11784 It's not very clear which way you're meant to slide it but if you look further down it shows how to refit it, so it looks like you need to slide it downwards, perhaps lifting the back end with something that's not metal to clear the bracket.
a double barrel shotgun, the only guarenteed way to remove loose trim on all cars.
On a more serious note with french cars the torx heads are essential, a small phase tester is always handy to have, a pair of wire snips, a pair of plyers, a socket set up to 13 for the interior. A hammer (for gentle persuasion) and some pry tools for the visible parts of the car and thats all you need to strip out the interior of a 406, or most cars.
...and since you're working in an environment where torn metal and broken glass are an everyday occurrence (hell, you may break the windscreen if you're not careful), a pair of very sturdy workman's gloves, and possibly some safety glasses.
A few cuts and bruises arent the end of the world, you end up with scars to show the women, you can tell them you fought with a lion.
HimBigChief
Post by HimBigChief »
You won't need much. Some smaller torx drivers to remove the roof light console so you can get to the wire connector (assuming it connects up there) and the mirror slides up IIRC to get it off. If you want the mount, then that'll be a complete bitch to remove as it's glued on there pretty damn well! Aim for a mirror which uses the same mounting method, which seems to be a pretty common one on quite a few cars.
Image Image
no2lurch
Post by no2lurch »
how the hell does the trim that covers the bracket come off?
no2lurch
Post by no2lurch »
anyone able to help me with this?
a bit of brute force
stealthe
Post by stealthe »
The mirror should slide down the windscreen to release, needs a bit of force and a wiggle.
stealthe
