dash lights etc. out with the Red!
Posted: Tue Jan 18, 2011 9:10 pm
by lozz
as anyone changed the colour of there dash lights/ mfd radio etc,
im getting fed up with the Red and im thinking of having a go at getting them to light up blue,
is it just a case of changing the bulbs or is it down to a couloured plastic creating the red?
Re: dash lights etc. out with the Red!
Posted: Tue Jan 18, 2011 9:36 pm
by Gary406
on my D8 clock i soldered a red LED instead of a bulb and it didnt light it up correctly
i think your right saying its a red screen that makes it red , usually all the bulbs are white so i think adding blue bulbs probably wont make it blue mate
will make it dim and not light properly
Posted: Tue Jan 18, 2011 9:44 pm
by lozz
Gary406 wrote:on my D8 clock i soldered a red LED instead of a bulb and it didnt light it up correctly
cheers
iwill have to strip down the clocks and see what makes them light up red,
if its just plastic or whatever itscalled that omits the colour iwill just sand it off and add blue bulbs
ive also got Some special blue paint desighned for bulbs so that might just do the job on the plastic
Posted: Tue Jan 18, 2011 9:48 pm
by Busman
When I replaced the bulbs on my radio display the bulbs were white, so it must be the display.
Posted: Tue Jan 18, 2011 9:54 pm
by lozz
Busman wrote:When I replaced the bulbs on my radio display the bulbs were white, so it must be the display.
Good point that
ive put wrong bulbs in my mfd and its throwing off a bright yellow light not Red ,
iwill try out some blue paint on them Tomoz and see what happens,
Posted: Wed Jan 19, 2011 6:28 pm
by Blue406
The red/orange colour comes from a layer of colour added to the dial face. All the dials are printed onto one sheet of plastic that has a colours backing.
You could, in theory sand down the coloured layer and then replace the bulbs. I'd recommend getting a set of dials from a scrapyard to test on.
Posted: Thu Jan 20, 2011 4:16 am
by FarmerPug
i looked at the d9 mfd because its one of the bigger obstacles, the back of the lcd screen has an orange foil, peel it away and replae it with blue foil and the display is blue.
Posted: Thu Jan 20, 2011 11:28 am
by lozz
FarmerPug wrote:i looked at the d9 mfd because its one of the bigger obstacles, the back of the lcd screen has an orange foil, peel it away and replae it with blue foil and the display is blue.
Cheers,
ineed a new mfd anyway so iwill take the old one Apart and see What ican do with the plastic eferjy thingy,
ijust need to find a Mfd all the breakers dont seem to have any- and im not impressed with what they want for em on Fleabay
Posted: Fri Jan 21, 2011 12:36 am
by FarmerPug
£20 i got one for and only bought it for the panel holding the 3 bulbs at the back.
Posted: Sun Feb 20, 2011 7:55 pm
by pfusi1
Bit late and its an old post but just thought I'd add my bit in case anyone is searching through.
When the bulbs went in my mfd I replaced them with white leds, however they didn't look right and you could see three circles of light through the front of the display. I then changed them for white bulbs and it didn't look red enough. In the end I put red bulbs in and it looked all good again.
So in short, I think you need red bulbs in the mfd and don't both with leds because the light doesn't spread out properly!
Posted: Sun Feb 20, 2011 8:10 pm
by lozz
pfusi1 wrote:Bit late and its an old post but just thought I'd add my bit in case anyone is searching through.
cheers for that mate,
ive now got a spare Mfd so im going to have a play this week & see if ican suss out how to change the colour,
there as to be away maybe blue plastic might be needed,
Posted: Sun Feb 20, 2011 8:37 pm
by plod
sure I read a thread over on the coupe forum today, and they were in process of swapping to purple and had pic to prove
Posted: Sun Feb 20, 2011 8:42 pm
by lozz
plod wrote:sure I read a thread over on the coupe forum today, and they were in process of swapping to purple and had pic to prove
cheers mate,
icarnt get on the Coupe forum ijoined but didnt get an Activation Email from them for some reason,
never been a member on there b4 so couidnt see why,
im happy on here anyways
Posted: Sun Feb 20, 2011 9:47 pm
Whoever it is that handles your email account may have decided it was junk mail and intercepted it. I just turned all that off on mine 'cos it was blocking emails from a mate of mine. You should see the size of my John Thomas now!
Posted: Sun Feb 20, 2011 10:08 pm
by lozz
steve_earwig wrote:Whoever it is that handles your email account may have decided it was junk mail and intercepted it. I just turned all that off on mine 'cos it was blocking emails from a mate of mine. You should see the size of my John Thomas now!
cheers mate,
yup it couid be something todo with my Email account, with it being Hotmail might cause a problem,
dont think il bother reaplying tho,
im staying on here
