Peugeot 406 - did it have Webasto as an optional?
OdinEidolon
Re: Peugeot 406 - did it have Webasto as an optional?
Post by OdinEidolon »
steve_earwig wrote:I don't think so, I think that was about the additional heaters - if you could supply these with an alternative 12 volt power supply all you'd need then is something to pump the water about. That is, if your car has them in the first place (but there's always possibility of retro-fit...)
The standard water pump is driven by the cam belt...
Edit: Not exactly a glowing recommendation http://www.benzworld.org/forums/unimog/ ... eater.html
Right, my bad. How do I know if the car has those heaters? All I know is that the 406 is blazingly fast at heating up in the morning.
OdinEidolon
where do you plug those into?
They're mostly core plug heaters - remove core plug, fit heater. Note they're mostly Canadian and it does get a touch cold there...
OdinEidolon
steve_earwig wrote:They're mostly core plug heaters - remove core plug, fit heater. Note they're mostly Canadian and it does get a touch cold there...
But then before starting I have to remove them and refit core plug!
Nooo, it stays plugged into the engine.
OdinEidolon
steve_earwig wrote:Nooo, it stays plugged into the engine.
But doesn't the engine need a core plug?
EDIT: Ok, forget it.
Those core plug heaters are cheap and effective! Why then a dfferent type of heating, such the one I posted earlier?
Not when the hole's blocked with a heater plug :wink:
OdinEidolon
steve_earwig wrote:Not when the hole's blocked with a heater plug :wink:
So it's effective, it's cheap, where can I buy one?
That might be a problem, for some reason DEFA fits core plug heaters to other engines but not the HDi :? It might be prudent to ask them why. I emailed Kenlowe back in 2007 and they said their hot start could be fitted to the HDi no problem :frown:
I guess if a core plug heater is ok for an HDi you'd then have to find one the right size from ebay Global and a transformer to run it.
I didn't actually find a core plug heater price on DEFA either. I'd guess a 1.9 but I wouldn't put money on it.
OdinEidolon
steve_earwig wrote:That might be a problem, for some reason DEFA fits core plug heaters to other engines but not the HDi :? It might be prudent to ask them why. I emailed Kenlowe back in 2007 and they said their hot start could be fitted to the HDi no problem :frown:
Uhm... anyone has info about the size and/or some pics?
One of the numerous "what the f**k is this?" threads was about this, there were pictures but I can't find it :(
steve_earwig wrote:One of the numerous "what the f**k is this?" threads was about this, there were pictures but I can't find it :(
Dont know what happen d to the pics mate,
there seems to be a few pics missing off varius threads,
noticed this about a month or so ago, :?
Was reading the haynes manual the other night,
on the citreon picassos the hdi ones theres some sort of thing looped in with the heater pipes with wires going to it,
this might pre-heat dunno how they work
looked on the 406 haynes theres no sighn of one of these things fitted to them
if there on citroens why did the pugs get missed out, after all there a sister/brother company :|
Pickarsehole? Interesting...
TURBO DIESEL DW10TD AND AUTOMATIC ADDITIONAL HEATING
6462 F5 WATER REHEATER - UNTIL RPO No. 09491
6462 Q0 - BSI COMM 2000 SINCE RPO No. 09492
This appears to be a box with a pump inside, plumbed into the heater feed pipes. There's a few other bits of stuff including some sort of control unit. Oh, and there are seal kits for them too.
If they don't have that, they have:
DIESEL DV6 AND WITHOUT ADDITIONNAL HEATING OR TURBO DIESEL DW10TD AND WITHOUT ADDITIONNAL HEATING
A) SALE WITH 4 PLUG
6462 E1 RP 6462 T7 WATER REHEATER - UNTIL RPO No. 10912
SEE A
6462 T7 - SINCE RPO No. 10913
I tried all the part numbers on ebay and in google, the T7 was the only one I got a hit for:
http://www.fbt-parts.com/?index=default ... 0&lang=840
I also stuck the number back into both Service Boxes, the t7 was the only one I got any hits for, other than the Picasso:
1 document(s) found for XANTIA II
1 document(s) found for BERLINGO (M59)
1 document(s) found for XSARA PICASSO
2 document(s) found for XSARA II
1 document(s) found for Partner (M59)
4 document(s) found for 306 (RESTYLING)
7 document(s) found for 206
1 document(s) found for PARTNER
So I first hit PARTNER and there it is again, then hit XANTIA II and, along with this little gadget, I get:
DW10 TURBO DIESEL
A) SALE WITH 4 PLUG
6462 C4 NFP WATER REHEATER - AUTOMATIC ADDITIONAL HEATING
So obviously there are a few of these things :?
