Blue dash lights (D9)
I've eventually got round to uploading the pics of my blue dash. It was quite easy to do just got to have a (slightly) steady hand .
- Attachments
- (33.17 KiB) Downloaded 3 times
"I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me. Your car...is your story. So don't let someone else write the book." - Moog
Re: Blue dash lights (D9)
Looks the business mate. What did u use? Leds? How did you do the clock ones?
Peugeot 406 2.2Hdi Coupe '02' Plate
Metallic Black(silver & black edition)
Manual, Rear Tints.
Manual, Rear Tints.
very nice mate.
thats what idid with mine but had to stop on the heater controls,
iguess youve been soldering
that looks very good.
in some clocks the illuminator bulb is just a 501 side light bulb in a big holder.
i replaced mine yesterday with white LED 501 side lights. theres 7 in total on my clocks.
The mfd is same as sidelight bulbs,
but the heater/aircon pannel is solderd in bulbs , smds ithink they are,
ihad abash at it but its very fiddly,
ye my main clocks use standard sidelights as well
- Captain Jack
Didn't you need to scrub off the white stuff from the back of the MDF to get rid of the orangey glow. Love this though... looks very good, especially the clocks.
2013 - 2021: 2007 Peugeot 407 2.2 HDI 170bhp Executive Saloon (mapped to 213bhp )
The clocks were smd bulbs that had to be soldered on just like the mfd. The bit with the clock was them twist in bulbs. The mfd had an orange bit of plastic on the rear, all I did to solve that was take it out and replace it with a bit of a cravendale milk carton then put blue lights behind it . I've also done the cigaret lighter soket blue and all the window switches
Looks very cool that
That looks absolutely awesome.
Owned:
3.0 V6 Estate D8- Killed by a drunk driver outside my home!
2.2 HDi Coupe Ariane Blue- Exported and now lives in Germany.
3.0 V6 Coupe D9 Polaris Blue- Sold to another Scotsman.
3.0 V6 Coupe D8 Polaris Blue- Still owned.
3.0 V6 Coupe D9 Pulsar Yellow- Still owned.
407 SW 2.0HDi Executive- Daily wagon, still owned.
- NineWhileNine
- 1.6 8v
That looks great.
I want my dials like that too, but I would prefer the needles to be red. Would this be possible?
Cheers
Dave
Cheers
Dave
1987 Fiat X1/9
2002 406 Coupe S&B 2.2 Petrol Manual
Done: JVC KD-DB101 into stock JBL Amp/Speaker & Stalk Control - DAB Aerial - Strut Brace - De-badged - Flip Key Fob - Air Freshener
To Do: Trip Computer/Stalk Button - Renew Air Freshener
It should be possible. Theres a white led under the needle that makes it glow white so i dont see any reason it wouldnt glow red if you changed the led to a red one.
- NineWhileNine
- 1.6 8v
Cheers JD406!JD406 wrote:It should be possible. Theres a white led under the needle that makes it glow white so i dont see any reason it wouldnt glow red if you changed the led to a red one.
Can I ask how many LED's you used for your setup? So I can make up a shopping list.
Dave
1987 Fiat X1/9
I think I bought 30 smd's, 3 twist in bulbs and 10 of them little led's with the 2 long legs (sorry I can't remember what they are called). That did the mfd clocks and window switches.
What colour you doing if you don't mind me asking.
- NineWhileNine
- 1.6 8v
Cheers Mate
I was planning to do the blue backlit dials like yours. I have since been massively put off the idea as it seems that it wont be a case of simply twisting out the old bulbs and replacing with twist in LEDs. Later dials are backlit by the those tiny LEDs mounted directly to the PCB.
Way too much faff, if at all possible.
1987 Fiat X1/9
