white dash lights. with pics and guide
Posted: Thu Jun 14, 2012 2:12 am
2002 406 Rapier 90 HDi Dash LED colour change
first off this is easy if you know how to solder and have a real temp controlled iron or hot tweezers.
If you have a £5.99 halfrauds soldering iron with a tip like a donkeys you know what then give up now please.
LED's. This board uses 10 x 3528 led's (the size of the led's) for the dial backlight.
2 x 3528 led's for the lcd backlight and 4 x 0608 or 0805 sized led's for the needle lights. ( i did'nt measure them ooops)
If you fancy ya chances at doing it then here goes..
Start by removing your dials.. nice and easy. there is a tute on the forum how to do it.
Ready to get going
Unclip the front Clear plastic to get access to the needles and dials.
Remove the needles (use a pair of spoons to gently lift them up)
Remove the dials they should just lift off once the needles are gone.
NOW a wee tip. up to you if you use it tho.
take a black marker and colour the top of the led's marked with the arrows (it will help later on)
Closer images of the LED's to change
Now you are ready to remove the white plastic housing.
Turn the unit over and with a pair of pliers straighten the metal clips (these hold the millage lcd in place)
Turn the unit front side up and gently remove the small metal bracket the holds the lcd in place.
Gently lift the lcd up and it should release with the rubber contact bridge still attached to the lcd. (put it somewhere safe)
Once its safely out of the way turn the unit back over and un-clip the circuit board from the White Housing
This leaves you with the circuit board ready to de-solder the led's and solder in your new led's
I used a green marker pen and it was difficult to see in the picture so i suggest as above to have used a black marker.
Images of the led locations with arrows to help out if you didnt use the black marker pen tip..
To change the lcd colour there are two led's that sit directly behind the lcd screen (that you removed and marked earlier)
If you want to change the needle colours you have to press the center of the pins thru from back to front on the 2
clips that hold the small needle servo to the board. Under each servo you will find a tiny poss 0608 sized led.
I cheated here and put a small bit of coloured lighting gel over the led ( as in spotlight colour filter gel)
Refit the servo and push the pins back thru from the front of the servo to lock it back in place.
( be careful not to push the pins right thru but push them in so they are flush with the back of the servo clip)
Once you have changed all your led's over to your new colour rebuilding is just the reverse process.
Clip the circuit board back into the white housing.
place the lcd screen back into the correct place and put the metal holder back on then bend the clips on the back side of the board.
place the dial plastics back over the needle holes and make sure to seat the middle part of the tacho and speedo dials.
line your needles up and gently push them home.
Place the front glass back over the dials and it should be job dun.
Hope it might help out if anyone decided to have a try.
Chris
Ready to get going
Chris
