Rattle behind the glove box
Posted: Mon Nov 11, 2013 9:32 am
by Captain Jack
Over the past few days, I have been getting some rattling from the glove box area. I removed all the crap I had from there and it still rattles - even going over a small bump I hear it.
Before I start hunting for the cause, are there are known loose bits there that tend to break off? I know BSI is there as well as some recirculation fan/flap thing - are these prone to working loose causing a rattle?
Re: Rattle behind the glove box
Posted: Mon Nov 11, 2013 9:43 am
by mjb
BSI's driver-side. Try removing the glovebox for a drive?
Posted: Mon Nov 11, 2013 9:58 am
by jonsowman
The lock barrel on the glovebox is a known rattle suspect!
Posted: Mon Nov 11, 2013 10:05 am
by Captain Jack
I was sure the BSI is behind the glove box...
It's definitely coming from behind the glove box somewhere - drove with the glovebox open and the noise was exactly the same. Will certainly remove it at some point.
Posted: Mon Nov 11, 2013 10:29 am
by GingerMagic
The glovebox is only held in by 2 plastic pins, takes 10 seconds to remove it. There are a few things lurking behind it, blower, recirculation motor - likely suspect - and various hoses etc. POP the box off and go for a spin after wiggling whatever you can wiggle behind it....
Posted: Mon Nov 11, 2013 10:37 am
GingerMagic wrote:The glovebox is only held in by 2 plastic pins
If only
That's how the lid comes off, the rest is screws, one of which is a female dog to get to. Here's Frank's recirculation flap how-to which covers glove box removal
http://youtu.be/hDgZBsBfR3s
Posted: Mon Nov 11, 2013 10:49 am
by Captain Jack
That's a useful video! Never took it apart that far!
Posted: Mon Nov 11, 2013 10:58 am
by jonsowman
Oh the fastener from hell, that took me forever to get to. What on earth were the designers thinking?!
Posted: Mon Nov 11, 2013 11:11 am
Something along the lines of "that'll do, my mistress is getting cold"
Posted: Mon Nov 11, 2013 4:42 pm
by markw
I wondered how in the hell they got that torx screw in there in the first place......
Posted: Wed Nov 13, 2013 4:01 pm
by Captain Jack
Found it - the bolt/screw holding the passenger air vent came off, dropping the vent on top of one of the support struts. A zip tie later and all fixed!
