I have attained 2 x illuminated sun visors to replace the standard ones in my 2001 Rapier (90 HDi Estate). They come with a wire and plug which obviously goes into a loom/socket. Trouble is I can’t find this anywhere — not behind the A pillar nor behind the front courtesy light. I presume it’s fitted to all cars the only difference being the ‘better’ models had the accessory fitted rather than just the wiring. I can manually splice it into existing wire but would rather know if it can be plugged in!
Also, the previous owner of my car (only two of them!) had wrapped black electrical tape around the gear knob. I unwrapped it out of curiosity and because it was a mess and discovered that the knob was cracked (no Kenneth Williams quotes...) Will but a new one but in the meantime, it won’t fit back on properly and is loose. It appears to slide onto a plastic sleeve which is also cracked. I could ramble on but does anybody know how these work? If you want pictures I’ll get some uploaded.
Thank you! In the meantime, Pug has covered 6k since January and is going great. Had to replace the rear anti roll bar links which were knocking but all is good. Full service when the weather is better.
