Hey,
I have a 406 2.0i lx (97) and I am looking to fit a couple of 6x9's on the parcel shelf, I already have them as I took them out my old car...
I have a couple of questions I need advice on, currently there are factory fitted rear speakers on the parcel shelf, is it easy to remove these and replace them with the 6x9's (I realise I may need to cut the hole a little bigger), or would you advice I leave the factory fitted rear speakers in and place the 6x9's either side them?
Will the wiring from the factory fitted speakers be compatible with the 6x9's so it's a simple case of swapping the wires over?
Thanks in advance
Speaker fitting advice...
- MaDc0w
The old ones are easy to remove.
BUT
Most aftermarket ones' magnets do not fit through the holes of the standard ones.
I rebuilt the parcel shelf so I could lift them higher.
There are aftermarket 6x9s that do fit. I think it was here on our forums under I.C.E
Cables you can leave if you want.
BUT
406OCWelton wrote:Couldn't help it........... at first it was the picture of the 2 tone grey 406........and then later the monitor just got sprayed
- jameslxdt
get the JBL coupe 6x9's
they fit perfectley and have awesome sound quality
