How easy is it and how is it done?
Dash removal
- nick
- Site Admin
Re: Dash removal
the instrument cluster? p-easy.
on a D8 - lower the steering wheel - get the 3 torx screws out from the top bit - then CAREFULLY prose the fascia out (careful - this also includes the 2 fans to the right and the left one).
To remove the instrument cluster - take out the 4 torx screws holding it in and jiggle it a bit so it gets loose, then pull out.
N
N
Thanks,
Nick
Nick
DaiRees wrote:I got the "premium" standard fit system in mine, 10 speakers, changer, JBL amp. I'm quite happy with it for listening to the radio / CDs or my "teach yourself Welsh" stuff on the way to work
- mav
Re: Dash removal
that or with a big crowbar
warning
dont use this method if you want to put it back on tho
mav
mav
The answers no!
Now whats the question?
Re: Dash removal
Ok thanks. Whats the difference between a D8 and D9? Have seen them about on here and wondered what the differences are (and what years they were made)
Lol love the crowbar approach but not really practical
- 1.6 8v
Re: Dash removal
BUMP to the top for the same question - how to remove the dash (and put it back!) to get at the cluster...Toby wrote:Ok thanks. Whats the difference between a D8 and D9? Have seen them about on here and wondered what the differences are (and what years they were made)
... and what are the model years for D8/D9 (and where does the classification come from?)
- DaiRees
- Site Admin
Re: Dash removal
Nick's spot on with how to get the instrument cluster out, lower the steering wheel, remove the 3 torx screws (they're at the top of the bit surrounding the cluster) then very gently start pulling it towards you, you may want to encourage the end bits around the vents by levering, if so use a wide flat blade and carefully work it in between the hard plastic and the soft dash.
Then when the surround is out, there are another 4 torx screws at the top of the cluster, once you've got these out you should be able to pull the cluster forward, although there is a clip right in the middle at the top which you may wish to release using a flat blade screwdriver.
Refitting is the reverse of removal as they say.
D8 = phase 1 406 produced from 1996 to 1999.
D9 = phase 2 406 produced from 1999 to 2004.
Easy way to tell is to look at the headlights / grille. D8 had normal headlights and a slatted grille, D9 (like mine
) had longer, clear headlights and a mesh grille.
Hope that helps.
Hope that helps.
Re: Dash removal
DaiRees wrote:Nick's spot on with how to get the instrument cluster out, lower the steering wheel, remove the 3 torx screws (they're at the top of the bit surrounding the cluster) then very gently start pulling it towards you, you may want to encourage the end bits around the vents by levering, if so use a wide flat blade and carefully work it in between the hard plastic and the soft dash.
- 1.6 8v
Re: Dash removal
Top advice yet again, thanks guys
