Working through the minor faults on my 53 plate 406 HDi, i'm now on the seats.
They squeaked like a bitch when I moved my legs to operate the pedals, drove me nuts so I checked the bolts and they were all a bit loose, especially the two on the rear of the seat.
The front passenger seat was the same so I tightened them all up and all was silent. Felt wicked, for about two weeks until the driver seat started doing it again.
Is this a common thing or could a previous owner have been messing about with them?
If I find they are loose again, is there a way to do the job permanently, I thought about using spring washers?
I'm not sure if they screw straight into the floor or whether there is anything I can change to get them really tight.
I other thing. The plastic bits aroung the stereo creak badly when they expand from cold. Any way to stop this without replacing them?
I know i'm fussy but I do alot of miles and it drives me mad.
Thanks for any info
Mark
Squeaky seats
Re: Squeaky seats
Try thread lock on the screws, I have a feeling they should have had this on them already.
You could try something like rubber and nylon lubricant on the plastic trim. I wishI could stop my door panels from creaking...
- mjb
- Site Admin
Re: Squeaky seats
Could try some threadlocker on the seat screws?
- 1.6 8v
Re: Squeaky seats
I'll try some locknut.
Dint know you could get nylon/rubber lubricant. Would you get that from Halfords or somewhere like that?
Not noticed the doors. Youve started me off again now. haha
- 2.2 16v
Re: Squeaky seats
The headlining creaks on mine, just above my head, next to to moonroof.steve_earwig wrote:Try thread lock on the screws, I have a feeling they should have had this on them already.
Re: Squeaky seats
While clean my car a little while after i got it i noticed that 3 or 4 of the bolts for the front seats where about half way out on mine. I ve not checked them in a year or so maybe i should...
1997 Honda Prelude 2.2 VTi
Re: Squeaky seats
My front seats squeek, BUT it's coming from the seat belt catches. very tiny movementsin there as the car moves causes a little squeek which I eventually found to be the seat belt catch.
I solved it by driving without the seat belts.
(only joking
Actually I daren't squirt any lubrication down the catch in case something happens (pre tentioners, air bag etc)
(only joking
Re: Squeaky seats
If the seats are leather get some leather softner cream, leather seats need softened or they squeak or so the salesperson told me.
