courtsey lights in door cards please help
i have just fitted the door cards off a exec on to my lx the lights was not on my old interior so i pluged in the white plug into the light on all four doors and nothin happened i checked all the bulbs and they are fine can anyone help with this and how i can get them workin thanks in advance
- mjb
- Site Admin
Re: courtsey lights in door cards please help
The wiring's probably missing from the body looms
- Site Admin & Mad Biker!
And running cable from the door to inside the car through that fixed gland is a mission and a half!! Mind you, you'd only need to take a feed from the switched side of the courtesy light switch next to the door hinge.mjb wrote:The wiring's probably missing from the body looms
- mjb
- Site Admin
and then do the other 3 doors... ouchteamster1975 wrote:And running cable from the door to inside the car through that fixed gland is a mission and a half!! Mind you, you'd only need to take a feed from the switched side of the courtesy light switch next to the door hinge.
It sounds like the wiring exists inside the doors, presumably it's missing in the car thoughmadbaggie28 wrote:...i pluged in the white plug into the light on all four doors
I wonder if it's the old BSi again.....
Has it got elec rear windows? ....yes
Has it got climate control?....yes
Has it got courtesy lights in the door cards?....no
Maybe follow the wiring back? if it goes into the BSi (near steering column) then the BSi will have to be told to switch the lights on (dealer software).
wil have to be turned on with pug software. if you come up near chester any time i can poss help out
