courtsey lights in door cards please help
Posted: Mon Nov 10, 2008 11:39 pm
by madbaggie28
i have just fitted the door cards off a exec on to my lx the lights was not on my old interior so i pluged in the white plug into the light on all four doors and nothin happened i checked all the bulbs and they are fine can anyone help with this and how i can get them workin thanks in advance
Re: courtsey lights in door cards please help
Posted: Tue Nov 11, 2008 5:00 am
by mjb
The wiring's probably missing from the body looms
Posted: Tue Nov 11, 2008 12:30 pm
by teamster1975
mjb wrote:The wiring's probably missing from the body looms
And running cable from the door to inside the car through that fixed gland is a mission and a half!! Mind you, you'd only need to take a feed from the switched side of the courtesy light switch next to the door hinge.
Posted: Tue Nov 11, 2008 12:57 pm
by mjb
teamster1975 wrote:And running cable from the door to inside the car through that fixed gland is a mission and a half!! Mind you, you'd only need to take a feed from the switched side of the courtesy light switch next to the door hinge.
and then do the other 3 doors... ouch
Posted: Tue Nov 11, 2008 4:34 pm
madbaggie28 wrote:...i pluged in the white plug into the light on all four doors
It sounds like the wiring exists inside the doors, presumably it's missing in the car though :(
Posted: Wed Nov 12, 2008 8:47 am
I wonder if it's the old BSi again.....
Has it got elec rear windows? ....yes
Has it got climate control?....yes
Has it got courtesy lights in the door cards?....no
Maybe follow the wiring back? if it goes into the BSi (near steering column) then the BSi will have to be told to switch the lights on (dealer software).
Posted: Mon Nov 30, 2009 9:49 pm
by kebab22
wil have to be turned on with pug software. if you come up near chester any time i can poss help out
