Got my whole new interior in and it looks fantastic, just the cream plastics to paint black now to smarten it up a little more.
As I said in a previous post I got a Seat ECU with the correct wiring soldered to the positive and negative wires, positive 30a fused running directly from the battery.
Where do I connect the yellow connector to on the passenger seat, I tried yellow to a yellow connector but it didn't power any motors and looked to be blank, so where do I need to connect this, it just feeds a negative and positive anyways so I can solder it to the switch if needs be but where do I do this?
The driver seat moves in all the correct directions up down, backrest etc but the rails don't slide backward and forwards, the motor runs but just doesn't move forward or backwards, any idea on this as the seat is midway front and I need it all the way back for the 6ft 8 of me to fit in, do I need to syncronise the motors or something, the ECU was out of a Coupe' would this make a difference?
Final thing to do with the electric I need to sort is the puddle lights on the door cards, the connectors are there on 3 of the 4 door but not the drivers door which is strange, I'll run a cable from the Door Jamb switch to fix thing, however the other pre-existing wiring has no power going to it, is there a fuse that could be missing, the car doesn't have a BSI being built in 1996 and registered in 1997.
If you can help me fix these problems, I would be truely greatful.
Seats in still need some advice, please.
