water in drivers footwell
Posted: Tue Feb 02, 2010 5:42 pm
by mk1rs
my 406 has a lot of water in the drivers footwell :evil: anyone has this problem ans solution ?
thanx
Re: water in drivers footwell
Posted: Tue Feb 02, 2010 10:02 pm
by Doggy
Could be sunroof drains, though other causes are possible.
Posted: Tue Feb 02, 2010 10:28 pm
Plugs missing from floor, leaky aerial (does it rain inside?), loose door seals, leaking windscreen seals, if you park facing downhill it could also be the tail lights leaking (ducks swimming around in your boot?), check the drains under the windscreen, at the back of the bonnet - they can block up with leaves etc. and the water drains into the heater.
Posted: Wed Feb 03, 2010 12:14 am
by mk1rs
thanx guys
car has no sunroof so looks like i need to get the hose pipe out as its pretty bad in the drivers well
also the brake lights dont work but thats probly just the switch
thanx
Posted: Wed Feb 03, 2010 12:27 pm
by rapierKen
mk1rs wrote:also the brake lights dont work but thats probly just the switch
thanx
the switch is only a few quid from most autofactors, (easy to fit if you have small hands!) if it isn't the switch have a look here as the brake light loom runs under the carpet.
Posted: Wed Feb 03, 2010 2:07 pm
by mk1rs
thanx for that
ive checked the rear drivers light cluster and some plonker aint even put the 2 nuts on that hold the light in place :shock:
so im guessing that the water is coming in from there
Posted: Wed Feb 03, 2010 3:28 pm
I still can't see how water can reach the footwell from the boot but plenty on here say it is possible :|
Hope you get it sorted.
Posted: Wed Feb 03, 2010 4:27 pm
steve_earwig wrote:if you park facing downhill it could also be the tail lights leaking
:P
Posted: Wed Feb 03, 2010 4:45 pm
by mk1rs
it was on my drive which has a small incline :cry:
