MFD and radio stays on
- 1.8 8v
Hi can anyone help, my mfd and stereo stay on, the stereo can be turned of manually, but the MFD stays on pemantantly, its also a bit dim, but guess thats because a bulb has blown, also the outside air temp just shows 2 dash's, guess the sensor has packed up, but it happened at the same time as the mfd wouldn't turn off with ignition, any ideas or is it a replacment mfd, its bloody annoying!!!!!!
Re: MFD and radio stays on
is this a d8 or d9
- 2.0 Turbo
I had this on my D9, not too often though. Only started happening after i fitted my connects2 stalk adapter for my Sony HU.
Never found a permanent cure but used to just unplug the MFD then plug it in next time im in the car, would sort it for weeks or months at a time!
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
2003 406 2.2 HDi SE
- mjb
It's probably something shorting the permanent live to the ignition-switched live. I'm guessing it's a D8 and you can also switch on the headlamps without the key, and the brake lights work without the key either... Usually this would be caused by a dodgy ignition barrel.
Have you fitted an aftermarket alarm system or anything else?
- 1.8 8v
Its a D9 model, 99 T plate hdi. The only thing i've fitted is a parrot hands free kit, witch also stays on, but the power is fed from the sterio permanent feed, even with the hands free kit unplugged it has no effect.
