UPRATED BATTERY
UPRATED BATTERY
is there such thing as upgrading batterys ?
if so what do i need to look for cos i have no idea, i see sumwere sells 60ah sum sell 61ah ?
im looking for an uprated battery to feed my amps better, 8) is that possible ?
Re: UPRATED BATTERY
Well yes, but you're limited by the size of the battery box. My D9 has the biggest battery I could find that fitted in there, it's a 75 amp hour but I'm sure there'll be better in the UK. Alternatively put another in the boot on some sort of split charge system.
omega
Re: UPRATED BATTERY
Post by omega »
battery are rated in amps so the bigger amps the better but make sure you can fit it inthe space
but most big stereo systems ive seen run seprate batterys so maybe a bigger alternator might help?
Re: UPRATED BATTERY
will my alternator charge 2 ? or will that need uprating ?
Re: UPRATED BATTERY
think this is going to extreme by the sounds of it, might invest in a power capacitor, 8)
thanks for replys i will take a trip to local motor store 2moro see what the biggest battery i can get in,,
cheers guys
