pugi406
Posts: 21 Joined: Tue Apr 13, 2010 3:50 pm
Post
by pugi406 » Wed Oct 13, 2010 12:47 pm
for what are these wires under the driver's seat and passenger seat
Posts: 19813 Joined: Thu Oct 04, 2007 6:09 pm
Post
by steve_earwig » Wed Oct 13, 2010 12:55 pm
The brown & blue connectors are for the side airbags and seatbelt pretensioners, not sure about the red one though
pugi406
Post
by pugi406 » Wed Oct 13, 2010 1:09 pm
Is it possible that something is for heating the seats.
or if there is anything extra that is only to connect or install.
Posts: 9656 Joined: Tue Jun 01, 2010 5:42 pm
Post
by FarmerPug » Wed Oct 13, 2010 3:30 pm
quick question since pugi406 has put up that picture and thanks because my camera doesnt seem to get it as clear as that. But anyhow when i did the permanent wiring of them faulty connectores under the seat, i did these, and if i recall correctly the design of the connector seemed to connect the two wires that went into each connector, and as such i just soldered the two wires together on the input side, and soldered them to the wire on the other side. Could that be good, ive got the airbag fault codes back and short circuit is mentioned somewhere, but even before i had done it the airbag light was on?
Post
by steve_earwig » Wed Oct 13, 2010 5:03 pm
I can't see how that would be right
pugi406 wrote: Is it possible that something is for heating the seats.
I don't know that that red connector is for but I'm sure it's not a seat heater
Posts: 7983 Joined: Wed May 31, 2006 9:06 pm
Post
by mjb » Thu Oct 14, 2010 10:52 am
Looks like it's going to the socket with the ground wire... so I'd guess it's grounding the frame for the airbags?
totaleclipse
Posts: 178 Joined: Sun Feb 22, 2009 10:52 pm
Post
by totaleclipse » Mon Oct 18, 2010 8:47 pm
steve_earwig wrote: I can't see how that would be right
mine has heated, electrically adjusted memory seats, with pretentioner, but no side airbag, and does not have the red plug.
1997 2.1TD executive estate - mmmm, lovely
Post
by steve_earwig » Mon Oct 18, 2010 11:26 pm
OOoh, must be something missing on yours then
(probably extra ground for the old bag as mjb suggests)
