Hi all
My drivers side electric window no longer goes down or up automatically i have to hold the button all the time, anyone else had this problem
Drivers Side Electric Window
- 2.0 Turbo
Re: Drivers Side Electric Window
Common enough issue the one touch feature wears out, the switch must be worn out, you could either buy a new one or perhaps someone else might have been able to fix it, they might reply later, But check that the switch unit is tight, take it out and make sure all the clips that hold it together are intact, otherwise you might need the new switch but they arent expensive out of a breakers, the trick is getting one without the same problem.
- lozz
dont know if this works on pugs but its worked on a lot of cars where the one Touch window up and down feature aint working
so it may be worth a Try,
> ign on,
>make sure window is up,
> press the window button in the up direction and hold it until you here a click,
this shouid reset the window -mech,
Dont know if it will work tho but worth a try,
iwill try it on my 406 tomoz outof curiosity
> ign on,
- sirwiggum
The mechanism on mine sticks, and often takes many tries of pushing the button on it's edge to get the window.
Especially annoying as the entrance to the work car park is keycard activated.
- TRAVIS BICKLE
- 2.0 Turbo
open the window, hold it in the down position till the relay clicks, the take it up inch bu inch, then hold the up button for about five seconds.
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
