passanger window wont work
is it a common fault? it works when i bang the motor but stops again after few days, had same problem on my e36 bmw, is there an easy fix?
Re: passanger window wont work
Not that I know of
Maybe it's just a dodgy connection.
doesnt work on drivers or passanger switch
connection going into the motor check that.
Amen to that. Sorted out the same issue in driver side window and it was due to corroded and oxidized contacts. Clean with contact cleaner and apply some oil to prevent further corroding/oxidizing. Slightly bent the pins of the male socket to ensure 'tight contact' with the female socket.406executiveHDI wrote:connection going into the motor check that.
2007, 407SW HDi 2.0l
1980, Volkswagen GolfD 1.6l
1996, 1.8(8v), SL ( The BEST Peugeot I've ever had. It kept me working on it, fixing it almost every day, I miss you)
my issue was the motor had been changed and wired up the wrong way round so up was down and down was up
