FarmerPug wrote:i cant really reverse a trailer thats what makes doing a trailer test more difficult. So the load bay on the pickup is fairly adequate.
Im not a big fan of towing trailers myself,
ican actualy Reverse a trailer withought hitting something but they can be a Mare sometimes especialy when your Going down roads and some plonkers are double parked,
Caravans are a hinderance too anything over 40mph and there a kite
whats all this about not being able to tow on your licence? Course you can,as long as its not above 750kg.thats a hell of a lot of weight for a trailer
If you passed your car driving test on or after 1 January 1997 and you now want to tow a caravan or certain trailers, you may have to take a specific practical test.
Car licences obtained before 1 January 1997
If you passed a car test before 1 January 1997 you keep your existing entitlement to tow trailers until your licence expires. This means you're generally entitled to drive a vehicle and trailer combination up to 8.25 tonnes maximum authorised mass (MAM). You also have entitlement to drive a minibus with a trailer over 750kgs MAM.
Car licences obtained on or after 1 January 1997
If you passed a car test on or after 1 January 1997 you're limited to vehicles up to 3.5 tonnes maximum authorised mass towing a trailer up to 750kgs, or a vehicle and trailer combination up to 3.5 tonnes MAM providing the MAM of the trailer doesn't exceed the unladen mass of the towing vehicle. You will need to pass an additional driving test in B+E if you wish to tow a caravan or trailer combination which exceeds these weight limits.
The car and trailer practical driving test
The car and trailer test (B+E) is based on the lorry driving test and lasts for approximately one hour. Please note that B+E tests are conducted at vocational (bus and lorry) driving test centres.
The towing test (B+E) includes:
* vehicle safety questions
* an off-road reverse manoeuvre
* a controlled stop
* uncoupling and coupling of the trailer and driving on the road
Your practical driving test will include approximately ten minutes of independent driving. This is designed to assess your ability to drive safely while making decisions independently.
1999 D8.5 HDi GLX - Sold
2007 Mondingo Zetec - I seek forgiveness Bring back my 406
Category B: Vehicles up to 3.5 tonnes MAM and with up to eight passenger seats
Category B vehicles may be coupled with a trailer up to 750kgs MAM (allowing a combined weight up to 4.25 tonnes MAM) or a trailer over 750kgs MAM provided the MAM of the trailer does not exceed the unladen weight of the towing vehicle, and the combination does not exceed 3.5 tonnes MAM.
For example:
* a vehicle with an unladen weight of 1.25 tonnes and a MAM of 2 tonnes coupled with a trailer with a MAM of 1.25 tonnes could be driven by the holder of a category B entitlement. This is because the MAM of the combination does not exceed 3.5 tonnes and also the MAM of the trailer does not exceed the unladen weight of the drawing vehicle
Whereas
* the same vehicle with an unladen weight of 1.25 tonnes and a MAM of 2 tonnes when coupled with a trailer with a MAM of 1.5 tonnes would fall within category B+E. This is because although the combined weight of the vehicle and trailer is within the 3.5 tonnes MAM limit, the MAM of the trailer is more than the unladen weight of the drawing vehicle
* Vehicle manufacturers normally recommend a maximum weight of trailer appropriate to their vehicle. Details can usually be found in the vehicle's handbook or obtained from car dealerships. The size of the trailer recommended for an average family car with an unladen weight of around 1 tonne would be well within the new category B threshold.
Towing caravans
As for towing caravans, existing general guidance recommends that the laden weight of the caravan does not exceed 85% of the unladen weight of the car. In the majority of cases, caravans and small trailers towed by cars should be within the new category B threshold.
An exemption from the driver licensing trailer limit allows a category B licence holder to tow a broken down vehicle from a position where it would otherwise cause danger or obstruction to other road users.
By passing a category B test national categories F (tractor), K (pedestrian controlled vehicle) and P (moped) continue to be added automatically.
Category B+E: Vehicles up to 3.5 tonnes MAM towing trailers over 750kgs MAM
Category B+E allows vehicles up to 3.5 tonnes MAM to be combined with trailers in excess of 750kgs MAM. In order to gain this entitlement new category B licence holders have to pass a further practical test for category B+E. There is no category B+E theory test. For driver licensing purposes there are no vehicle/trailer weight ratio limits for category B+E.
plod wrote:Category B: Vehicles up to3.5 tonnes MAM and with up to eight passenger seats
For example:
Whereas
* the same vehicle with an unladen weight of1.25 tonnes and a MAM of 2 tonnes when coupled with a trailer with a MAM of 1.5 tonnes would fall within category B+E. This is because although the combined weight of the vehicle and trailer is within the 3.5 tonnes MAM limit, the MAM of the trailer is more than the unladen weight of the drawing vehicle
Towing caravans
For example:
Whereas
Towing caravans
I likes nice big mams
