2000 W pug 406 fusebox
daviebhoy
Post by daviebhoy »
Hi there
I was wondering if someone can help me, I have a 406 estate 1.8 petrol 2000 , I am looking for a diagram or advice on where I could find the fuse for my window wipers ?
Many Thanks.
Re: 2000 W pug 406 fusebox
Greetings :cheesy:
It seems to be fuse 24 in the passenger fuse box (the one by your knee), the relay is, well, see if that's the right fuse first.
daviebhoy
Post by daviebhoy »
thanks m8. the fusebox is under the bunnet m8 ,do you think it will still be the same fuse you mentioned ?
daviebhoy wrote:thanks m8. the fusebox is under the bunnet m8 ,do you think it will still be the same fuse you mentioned ?
There is or shouid be 2 fuseboxes,
the other en is by your knee drivers side :roll:
