trip computer installation
Re: trip computer installation
I'd heard they only sold them in mainland Europe. Probably as much power as a fart in a whirlwind :roll:
a 1.6, a whirlwind has 10 times the power of that, fiat pandas are probably quicker. And why would they sell it in mainland europe, that gives it a chance to drive through the alps which in one of them would be a terrible experience. Judging from what its like to drive a 1.8 nissan primera with less than 120bhp, underpowered cars are not nice.
Could still arrive, along with the XUD auto.
Soon.
soon, it will be there in 5 minuites, ok 10, wait 5 more, and so on.
Is there a 1.6 auto? Slow would really be redefined.
PIT
Post by PIT »
Hi
Let me tell you, that I found it possible to get it work on 2.0 HDI engine. (On my Xantia :mrgreen: )
Image Image
The signal 1368 comes out from pin 63 on BOSCH EDC15C2 used in 2.0 HDI.
You don't have to worry about the existance of BSI in HDI models. It is not needed! Just connect everything as it is for petrol engine, and it works. 8)
In Bulgarian Peugeot forum we also have some 406 2.1TD with already activated trip computer :cheesy: They used pin 23 on EPIC DIESEL ECU.
So I think only 1.9 TD does not support it :)
plod
Post by plod »
PIT wrote:Hi
Image Image
8) 8) 8) 8)
That's good to hear as it's something i've wanted to do for some time, as I already have the stalk in place
1999 D8.5 HDi GLX - Sold :(
Wonder if those variable heated seat switches are the same size as the buttons in 406s... :lol:
(why why why why why did they use buttons instead of a variable control? :evil:)
RayneR
Post by RayneR »
mjb wrote:Wonder if those variable heated seat switches are the same size as the buttons in 406s... :lol:
from their look, it looks the size as the coins holder ( which is where the heated buttons go) on 406 ... by variable control, you mean you could adjust the heat generated ? :o
2000/May 406 Estate 2.0 HDI 110bhp DW10ATED now with 205k km & now with cruise control & now remaped @ 134bhp :lol:
PIT
Post by PIT »
I do not think only the buttons will be enough :) You may need the controller also.
And may be the variable switches from Citroen C5 which are quadratic will fit better from the rectangular one from Xantia... if they are not bigger...
RayneR
Post by RayneR »
PIT wrote:I do not think only the buttons will be enough :) You may need the controller also.
yeah.. that controller can be retro fitted to a 406 ? :supafrisk: :roll:
i hate so much shitroen, normally is the peugeot that gets the good things, apart from this i don't like citroen in general, they look so...weird and fragil in someway :evil:
APR
Post by APR »
maxxymilian wrote:Some new info on trip computing :) me and a couple of guys have been doing serious research on the toppic for a week. The result - two working board computers on a 2.0 16v (Bosch) and 1.8 16v (Sagem sl96) the trick is also avalable for 1.8 8v(Magneti Marelli 1AP.20) The thing is that on Bosch ECU-s lead 1386 is on pin 4. On Sagem and Marelli it is on pin 5!
Some usefull pics on connecting stuff:
http://img85.imageshack.us/gal.php?g=dsc05983r.jpg
Cheers form Peugeot Club Bulgaria 8)
So i can install the trip computer on my 1998 D8 1.8 Petrol ? I have to intall the sagem sl96 ?
plod
Post by plod »
Ooo splendid
Forgot about those pics
Going to print them off and get my electronics wiz mate to solder up like that in anticipation of getting the plug from Nutski
Have got a wire from behind the MFD into the engine compartment for going to pin 63 of the ecu, but won't connect that until have all the other wiring in place
plod
Post by plod »
Ooo splendid
Sorry but i'm confused again
I want this up and running, but don't want to solder direct to the board
I want the plug into the MFD and connect that way
Pin 2 coming out of the second connector goes to an earth - I have an earth lead in place coming up from the dash earth point ready for this
Which is the earth in the pics, so I can discount this?
According to the pictures posted in link above
The yellow and blue for the info from the fuel tank sender seams to go to the top bank of plugs - correct? - if so which pins
Pin 5 goes to the trip enabled wiper stalk - correct?
Pin 6 according to previous wiring diagram goes to pin 15 on the instrument cluster?
Pin 10 as with above goes to pin 21 on the instrument cluster
OR
am I making this too complicated and should just wire as in pics?
but as said would prefer to have it wired with the secondary plug
Sorry, thought I had it right in my head, but re-read the whole thread again, and just got a little confused - especially with not sleeping last 3 days out of 4 :shock: :( :(
Also
When I fitted the new wiper stalk, on the coupe forum, it talked of the connector needing a blue wire there for it to work, I'm sure mine is there, but where does it go to, or am I thinking of the wrong one???
Yours sincerely
Tired and Confused :wink: :lol: :lol:
APR
Post by APR »
